Changing tire size
Discussion in 'Gen 2 Prius Main Forum' started by GeoffM, Sep 20, 2004.
  1. GeoffM
    GeoffM Junior Member
    Long Island, NY
    Thinking about changing to a set of Goodyear Triple Tread tires as all the comments seem to be extremely positive. The problem is, the smallest size is a 19565R15, and the Prius seems to want a 185.
    Can I put 195's on the car, and if I do will I screw up the speedo, nav system calculations, etc?
    If the answer is no, then I'm also considering the HydroEdge from Michelin, but from what I've read there's a big difference of opinion over the road noise from these tires.
    All comments welcome.
    Thanks,
    Geoff
  2. olends
    olends New Member
    214
    Clifton Park, NY (near Albany)
    185
    Section Width: 7.28 in 185 mm
    195
    Section Width: 7.67 in 195 mm
    185
    Rim Diameter: 15 in 381 mm
    195
    RimDiameter: 15 in 381 mm
    185
    Rim Width Range: 5 - 6.5 in
    195
    Rim Width Range: 5 - 7 in
    185
    Overall Diameter: 24.46 in 621.28 mm
    195
    Overall Diameter: 24.98 in 634.49 mm
    185
    Sidewall Height: 4.73 in 120.14 mm
    195
    Sidewall Height: 4.99 in 126.74 mm
    185
    Radius: 12.23 in 310.64 mm
    195
    Radius: 12.49 in 317.24 mm
    185
    Circumference: 76.84 in 1951.7 mm
    195
    Circumference: 78.47 in 1993.1 mm
    185
    Revs per Mile: 850.3
    195
    Revs per Mile: 832.6
    185
    Speedometer1: 60 mph 100 km/h
    195
    Speedometer2: 58.7 mph 97.9 km/h
    195's
    Speedometer Difference: 2.125% too slow
    Diameter Difference: 2.09% larger
  3. GeoffM
    Long Island, NY
    Thanks olends,
    I found another thread talking about changing tires/wheels and also a real handy online calculator for comparing the dimensional differences between tire sizes. Doesn't really look like there's much downside to going to the 195's other than a bit of speedo inaccuracy and potentially small loss in mpg.
    Now all I need to find is someone who has tried the Triple Treds on a Prius!
    Geoff
  4. djasonw
    djasonw Active Member
    950
    116
    Coconut Creek, FL
    I read some good things about the goodyear assurance tires. I changed the OEM tires as soon as I bought my car as I really disliked them. I don't think you can go wrong with the next tire size. The MPG hit will be minimal. I also remember reading that there is a setting on the screen where you can set the tire size. Don't forget that the tire size in Europe is different. This is probably why they have this setting change available. If you do get the tires, let us know what you think. Also, please tell me where you service your car. I live on Long Island too. Thanks! :)
  5. GeoffM
    Long Island, NY
    I'm probably going to give the Goodyears a try. The dealer's going install them before I pick up the car on October 9th, and then I'll have a nice 1,000 mile ride home to see how I like them.
    As for service, I was about to ask the same thing from all the other LI Prius owners - who do you like??
    Geoff
    DLC82SV likes this.
  6. DLC82SV
    DLC82SV Member
    241
    119
    I would love to know before I spend $400 usd on winter tires, are the 195-65r15's ok knock to knock and do they rub in the rear with weight in the back?
  7. JimboPalmer
    12,470
    6,868
    Greenwood MS USA
    You are posting in thread last updated in 2004. There is a fair chance no one is still following it. Making your own thread with a title about your question may get better response.
    DLC82SV and Mendel Leisk like this.
  8. Mendel Leisk
    38,788
    I really doubt clearances would be any problem, but like you mention in the other thread, they want you to sign a disclaimer. You'll achieve a whole 1/4" more ground clearance lol, and throw off the odometer, "gearing" etcetera. Narrower snow tires are also more effective I think. I'd stick with stock size.
  9. Lucifer
    Lucifer Senior Member
    1,014
    485
    Nh
    195/65-15 is the correct size, the speedometer is correct with them, the 185/65-15 are undersized and the speedo is off 2mph @50mph, and no there are no body wear problems.
    DLC82SV likes this.
  10. DLC82SV
    DLC82SV Member
    241
    119
    My threads get moved and no 9ne can be pleased. I make my own they move it, I join one already in progress I get told to make a new one. I can't seem to please anyone, let alone everyone... Sorry
  11. DLC82SV
    DLC82SV Member
    241
    119
    My door says 185-65r15 and that's what I have on it, but my speedo reads 72 at 70 and my front bumper is always scrapping even at low low speed pulling in and out of driveways, gas stations, etc... So I want to run 195's if I can as to lift the front, even if ever so slightly as well as reduce the revolutions per mile in turn correcting my speedometer discrepancy.
