Changing tire sizes, okay or no?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Gstatus64, Apr 10, 2019.
  1. Gstatus64
    Gstatus64 Junior Member
    25
    Denver, Co
    Hey, so I really like the Michelin Defender tires, as I've had them on previous vehicles.
    My Prius comes with 195/55/16, which the defenders dont fit.
    The defenders fit rims of 195/65/15.
    Would it be okay to switch the rims? I have a tire company that's willing to do trade-in credit for my rims and my brand new tires I just bought from another store.
    So I would be going down an inch in the rims.
    The speedometer reads +2/3 mph at 50+ mph, and I have a mechanic that can correct the speed with the rim change.
    Would this be a good thing to do for the sake of the mileage of the tire or no? What are the benefits of the two tire sizes?
    Thanks in advance!
    Garron T
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    In my opinion, ABSOLUTELY not worth the time and trouble and money......even if they do fit OK.
    Find a Michelin model that does fit your present rims and learn to love them too.
  3. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    see if 205 50r16 is available. better traction, negligible mpg hit. they should improve speedo accuracy and look better too.
  4. caravan2429
    caravan2429 Junior Member
    64
    Sandy, UT
    I'm doing 195/65 R15 It is more stable than stock size and also corrects speedometer error a bit. It's comfortable but not good for handling if you drive aggressively. I would suggest you go for 205/55R16 or 205/60R15. I think these are balanced options to do.
  5. Mendel Leisk
    41,901
    Corrects a speedometer "error" that's there by design, and introduces an odometer error.
    kenoarto likes this.
  6. 69shovlhed
    2,170
    752
    Delaware
    making the speedo inaccurate by design is a stupid idea, but not as stupid as that damn bladder in the fuel tank. I wish I could get a European tank.
    kenoarto, Prius Rising and audiodave like this.
  7. dolj
    dolj Senior Member
    8,559
    4,349
    Wellington, New Zealand
    That's politicians and bureaucrats for you!
  8. Mendel Leisk
    41,901
    Making a speedometer "accurate" is impossible, with variations in tread diameters, tire diameters reducing as the tire wears, and so on. So they err on the side of safety; they never want you to think you're going slower than you actually are, to be speeding due to an low speedo. That's a fool's mission though.
    I'd rather keep my odometer reasonably accurate, but whatever floats your boat.
  9. Usle
    Usle Active Member
    317
    140
    Me
    2018 Prius Prime
    Your 195/55-16 tires are 24.4" in diameter, prius wants 25" in diameter for correct speedometer readings.
    195/60/16 tires are 25.2" in diameter.
    205/55-16 tires are 24.8" in diameter.
    I'd go with the 195/60-16" tires, better mpg's.
