Changing to Synthetic Oil, are these okay to use???
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by curtis0916, Nov 30, 2010.
  1. curtis0916
    curtis0916 Junior Member
    Abilene, KS
    I am planning to change my 2006 Prius with 70K miles to Mobil 1 Extended Performance 5W-30 oil and a Purolator PureONE filter (PL14476) and to change the oil & filter every 10K miles which would be around 9 months. I have read on this forum that these are good to use, but what bothers me is the filter states it should be changed every 3K miles and I have read people going 10K plus, is this the correct filter or am I considering the wrong one?
    I appreciate your help with this.
  2. Bob64
    1,540
    93
    Virginia
    Two things: Oil and Filter
    While the Oil may last 10k miles, the filter has a limited capacity to hold dirt and stuff.
    Purolator PureONE oil filters should be replaced every 3,000 miles or 3 months depending on the driving conditions - or unless otherwise specified by the vehicle's manufacturer.
    In this case, the recommended change interval is 5k miles for the filter... You can however, see if they'll last longer then that, but only at your own risk...
  3. uart
    uart Senior Member
    4,220
    1,209
    Australia
    The last few oil changes I've been going about 8500 miles on just synthetic blend (Valvoline Durablend 5W30) and the OEM filter. At the end of those 8500 miles it runs every bit as smooth and as powerful and with the same good MPG's as the day the oil was new. Also, when I drain the oil it still looks in good condition. I don't do a of of short trips though, so I'm sure my oil has a pretty easy life. :)
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    I use the same and go 10K also but use the original filter. Its approx $4. Its very cheap insurance. I know that filter has the correct bypass valve.
    I change the filter only every 5,000 miles and while I'm under there I lube the chassis.
  5. curtis0916
    Abilene, KS
    Is there an extended life oil filter that has been used for 10K miles with success?
  6. curtis0916
    Abilene, KS
    What is the part no. for the original filter and can it be purchased anywhere other than a dealership? I live quite a ways from a dealership.
  7. Britprius
    Britprius Senior Member
    5,194
    1,921
    Herefordshire England
    In the UK the filters are used for 10K miles regardless of maker but Toyota own is probably best. For some time now (years) oil and filter change interval has been 10K miles or 1year witch ever is sooner.
  8. don_chuwish
    don_chuwish Well Seasoned Member
    823
    190
    Southern Oregon
    Mobile makes a long life filter to go with their extended drain interval synthetics. I just put one on at the last oil change. Called "Mobile 1 Extended Performance M1-103".
    - D
  9. krg03
    krg03 Not expert, just experienced
    246
    31
    so cal
    ....and what are you planning on extending to?
    I do filter every 5k, oil change 15k. 5 prii all running dandy. Mobil 1, wix filter (upgraded fram, wix the same price in quantity). I watch for 5qt on sale and scoop up.
  10. don_chuwish
    823
    190
    Southern Oregon
    On both my cars I go to 10K and that's being conservative. I've done the used oil analysis (UOA) several times to verify that the oil is still in good shape at that point. UOA on my Odyssey showed that Amsoil was better at 10K than the Honda oil was at 5K. Blackstone said the oil could go even further but I'm not pushing it.
    This is my first time trying Mobil 1 though, so I may take a sample at 5K and send it in. Or I may not, everything I've read indicates that Mobile 1 is good up to 10K as well. Especially in the Prius where the ICE doesn't even run for a good portion of those miles, or idle when stopped, etc.
    - D
  11. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    With my FJ Cruiser I have to grease the zerks. But the entire time I owned my '04 Prius I never found a single zerk
  12. fuzzy1
    10,356
    Zerks? Some cars still have zerks?
    The last zerks I knew about were in my '84 Ford. And I thought they were put in by my parent's rural dealership, not by the factory, so they could be greased just like the tractors.
  13. lextoy
    lextoy Active Member
    291
    131
    philadelphia
    2018 Prius Prime
    here is a thread on extended oil change interval
    http://priuschat.com/forums/gen-ii-...9-why-people-using-oversized-oil-filters.html
    i am also using purolator PL20195 oversized filter. going 10k miles before change.
    i have 2 high performance german cars bmw benz, both typically go 12-14k miles before the computer tripmeter calls for an oil change. the filters are no larger than in our cars. with synthetic oils they are never badly clogged. just pulled valve cover on the benz at 110k miles, following computer ordered change interval approx every 12k miles, no buildup whatsoever.
    on our dinky prius engine, 4 quarts snthetic 5w30 and an oversized filter, on an engine that only runs 1/2 the time the car is running??? its no brainer. it wont be a problem at all.
    if it helps you sleep at night euro prius cars have recommended oil change interval of 10k miles :)
    i do check the oil level every 3k just to make sure, benz and bimmer are nice because they do it for you;)
    same car. different continent.
  14. lextoy
    291
    131
    philadelphia
    2018 Prius Prime
    pl20195 was on amazon special pricing, lucky for me the filter fits the 4runner also.
    funny thing is stock filter on the V8 4runner is almost as small as the prius filter. rediculous. i use the purolator on the 4runner also. toyota filters not worth the price, better filters can be bought for the same or less money.
  15. pEEf
    pEEf Engineer - EV nut
    720
    579
    Berkeley, CA
    I too, highly recommend the PL20195. Saw it open after your 10k change. It's really a nicely built filter compared to the junk Frams and such!
  16. jayman
    13,439
    641
    Winnipeg Manitoba
    The FJ Cruiser isn't a car, it's an off-road vehicle. Most don't have u-joint zerks, most Toyota trucks do
    But I haven't found a zerk on a Toyota car in perhaps two decades
  17. gary ellwood
    gary ellwood New Member
    Koloa
    I have my first Prius. Previously owned, it's a 2008 w/ 63,000 miles. I live on Kauai, and plan to switch to synth on this upcoming oil change. For decades, my conservative nature has caused me to change my dino oil in all my vehicles very 3,000 miles. From what I read here, could I put Amsoil synth in my Prius, use the Mobile 1 Extended Performance M1-103 filter, and go for 10,000 miles?
    Or am I being too aggressive?
  18. gary ellwood
    Koloa
  19. wjtracy
    wjtracy Senior Member
    11,365
    3,608
    Northern VA (NoVA)
    Mobil-1 is all I use and also the Mobil-1 M1-103 Filter. Walmart normally has these both in stock, or it has in the past anyway. Now that you mention it, I am overdue. Job for tomorrow. The Extended Performance Oil says 15k miles except for harsh use. The M1-103 high capaciy filter says 2x capacity. I usually try to change both before 10K miles. I am off warranty, but you should always follow warranty in any case.
  20. wjtracy
    11,365
    3,608
    Northern VA (NoVA)
    I changed to Mobil-1 early at 4000 miles. My guess is first synthetic re-fill at 63000 better to change it at 5000 miles, on the assumption you may do some initial degunking, and also you will still have some conventional oil hold-up in there. Then ramp it up to 10K next refill. The websites all have FAQ guidance (eg. www.mobiloil.com) so you can see what they say.
