Changing transmission fluid for the first time on an old Prius?
Discussion in 'Gen 2 Prius Main Forum' started by Emily_0021, Sep 8, 2014.
  1. Emily_0021
    Emily_0021 Junior Member
    NC
    My 2004 Prius has 152,000+ miles on it and has never had the transmission fluid changed (so far as I know). I got it with 117K but a transmission fluid change is not in the records.
    I will list my questions first and then share my "story" so that you don't have to read the details unless you want to.
    1. Should I change (drain and fill) the transmission fluid for the first time now after 152K miles?
    2. Has anyone else changed the fluid for the first time after 100,000+ miles and did any problems result from the change? Decrease in mpg? Damage to the transmission? Any benefits like an increase in mpg?
    3. If I should not change the fluid then should I just buy a quart of fluid and fill it until fluid starts coming out of the fill hole?
    Details:
    The last time I got an oil change, the yellow box on the 23-point inspection sheet next to transmission was checked but I didn't notice it until I got home. I called the dealership asking if this meant my transmission was going bad or something and they said it just meant the transmission fluid was low. I then asked if I should have it filled because I was about to drive across the country and he said no, just have them filled with your next oil change. (The yellow box next to brakes was also checked and they said this meant my brake fluids were low but I checked and the fluid is closer to the max fill line than the min fill line. So I don't know why the yellow box was checked.)
    After that I started looking into if I could fill/top off the fluid myself and learned that transmission fluid should be changed at certain intervals and realized that mine had never been changed.
    I've done some research and some people say that you should never change the transmission fluid if your car is old and hasn't previously had the transmission fluid changed. Others say it wont cause problems. I asked someone in the service department at a toyota dealership and he said that I should definitely have the fluid changed since I haven't before. I asked about possible damage to my car from changing it and he said they don't recommend a flush but definitely recommend draining and refilling the transmission fluid. I want my care to last another 100K+ miles and just got new tires so I want to make sure my transmission isn't going to go bad.
    Also, I am currently getting bad mpg (~39mpg vs normal 51mpg). The bad mpg started in May after a top engine clean and new tires during my trip from low elevation NC to high elevation WY. Then my mpg improved while living in WY after a month. Now I am getting bad mpg again after moving from high elevation WY to low elevation KS and has remained bad in KS for the last week. The gas engine seems to be running more but the battery holds charge over night and over 3 days without driving. (I turned it off with 5 blue bars and turned it on 3 days later and it still had 5 blue bars.)
    Please share your experiences if you changed your transmission fluid changed for the first time after 100,000+ miles and if any problems occurred as a result. Also, if you have any ideas about why I might be getting bad mpg, please share.
  2. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    Prius transmission isn’t traditional automatic transmission. In traditional automatic transmission there’s lots of hydraulics inside and if transmission fluid isn’t changed for long time dirt in old fluid can be only thing keeping the transmission working. Changing Prius transmission fluid shouldn’t cause any bad things to happen. Unless you screw up something while changing it.
    But I don’t know what those lights mean. If transmission is already bad changing fluid won’t fix it…
    Longinus876 likes this.
  3. JC91006
    16,474
    8,393
    Wherever you got that 23 point inspection, I would not return there. They seem to check items that need attention randomly. There is really no way to check the transaxle fluid level on the 2004. And your brakes should be checked again by a professional to make sure it's acceptable at 150k.
    It should be fine to change the transaxle fluid now, make sure you use Toyota ws fluid and preferably have it changed at a place familiar with the prius
  4. Britprius
    Britprius Senior Member
    5,194
    1,914
    Herefordshire England
    I strongly suspect your bad millage is down to the tyres fitted. Please let us know as much detail about the tyres you have, make, type name or number, size, and tyre pressures you are running at.
    Changing the transmission oil will do no harm and in fact it will do good.
    John (Britprius)
    Longinus876 and dorunron like this.
  5. Mendel Leisk
    38,644
    I must be superstitious, 'cause there's something compelling about "long time dirt in old fluid can be only thing keeping the transmission working". Just the thought that it's working fine, you change the fluid, and then something bad happens...
    Still, I can't rationally see a reason to not change the fluid, it's long overdue.
  6. Emily_0021
    NC
    My tires are Copper brand and were recommended (as one of the cheaper options) by a Toyota dealer. I am not sure of the type name or size. I was running at ~42 psi on my old tires. My new ones were set at 35/33 by the dealer. I let some air out once in WY (at high altitude) to get them around 40psi on all 4 tires. After a month in WY my mpg returned to normal (~50-52mpg). It remained that way for 2 months. I then made the trip from WY to KS 2 weeks ago and that is when the mpg went down again (~37-39). I checked my tire pressure once I arrived in KS and it was at >45 in all 4 tires after sitting for hours so I let air out the next morning so that the pressure is 42 in the front and 40 in the back.
  7. Britprius
    5,194
    1,914
    It would be best if you can give more detail on the Cooper tyres, but I do not believe they are LRR "low rolling resistance tyres" and as such will affect negatively your mpg figures. Your psi figures do not make sense if you have not added air after coming down from altitude.
    The difference between LRR tyres and ordinary tyres can mean the tyres more than pay for themselves in fuel saved over there life.
    John (Britprius)
    dorunron likes this.
  8. Emily_0021
    NC
    Well, if the tires alone are the cause of the bad mpg, then why did the mpg improve (return to normal pre-new tire state) after a month in WY on the new tires? I know the psi figures don't make complete sense but I can only explain it by stating that in KS the temp is 20+ degrees warmer than in WY so the air pressure in the tires went up... or perhaps the dealership said they set the tires at 35/33 but actually set them at 45/43. Tire pressure would normally go down after leaving high altitude but the high temperatures in KS increased the tire pressure.
  9. JC91006
    16,474
    8,393
    How are you calculating the mpg?
  10. tanglefoot
    tanglefoot Whee!
    625
    188
    Colorado
    The outside temperature makes a big difference in the operating efficiency. Gasoline engines and batteries operate more efficiently at warmer temps. Operating the cabin heater also usually causes a noticeable drop in mpg. Trip duration and route are also large factors. Driving trips of under 15 minutes each way usually delivery significantly lower mpgs than longer trips. Some routes are also better suited for fuel economy than others, even in the round-trip. There are numerous factors to consider.
    There was an account here on Priuschat (I wish I could find it again) of a maintenance shop manager who was performing Prius transaxle fluid changes on higher mileage cars, but was experiencing such a high transaxle failure rate after the fluid changes that he stopped performing the service. Possible theories include sediment or sludge loosened during the refill process. Changing Prius transaxle fluid is a polarizing issue. Most enthusiasts and forum participants are proponents of changing the fluid, but it isn't on the maintenance schedule and I bet that most Prius owners out there never have it changed. I'm at 45k miles, so I might change it sometime soon, but I'd be personally reluctant to change it at 152k.
    Is the yellow mark on the brake portion for the fluid or the pads/shoes?
    My favorite tire pressure is 44 psi in front and 42 psi in back. It seems to roll really nicely and deliver good mpg and handling while wearing the tires evenly. If I drop the pressure to 35 psi, it feels like I'm driving around on mattresses--I don't like it.
    #10 tanglefoot, Sep 8, 2014
  11. Britprius
    5,194
    1,914
    At high altitude there is less oxygen pulled into the engine this in turn means the car compensates for this and injects less fuel. Further the less dense the air the easier the car travels through it "less drag". These put together could explain why you got better fuel economy in WY.
    John (Britprius)
  12. Emily_0021
    NC
    I fill the tank until the auto-shut off goes on. Drive. Refill. The miles of a trip divided by the amount of gas to fill the tank=mpg. It's usually about 1-3 mpgs higher or lower than what the prius reports on the screen.
  13. JC91006
    16,474
    8,393
    If this is the method used, it won't be accurate. You would have to go with a running average with all your tanks and mpg combined. The gas tank has a bladder and it's very inconsistent in terms of amount of gas you can get in per tank
  14. vskid3
    vskid3 Active Member
    773
    228
    What is your AC usage compared to in WY? It can take a little while for the computer to fully adjust to the different elevation as well.
    Like JC said, don't worry if this was your first tank in KS. I've had tanks that were unusually low followed by high or vice versa, but the average of the MFD mileages was about the same as combining the pump mileage.
  15. dorunron
    dorunron Senior Member
    3,318
    1,103
    Houston, TX
    IMO, it is a combination of things. The bladder is doing it's thing. You can't go by tank to tank. The tires are probably not LRR tires. The air pressure from the different elevations effects it. And many other things too come into play.
    If it were my car, I would change the transmission fluid. Simply drain and refill with the Toyota WS. While you are it, clean the throttle body and the MAF sensor. Install a new air filter and fill it up with some good Tier 1 fuel. Then drive it normally and see if it does not improve.
    If the tires are not LRR (low rolling resistance) there is little you can do anything about that at this time. My best suggestion would be to fill the tires to the maximum amount of air pressure that is marked on the side of the tires, and maintain two pounds more on the front tires than the rear. When you get the next set of tires, be certain to get LRR type tires. Do some research on your own and know what you are buying. A recommendation from a dealer is simply them selling you a set of tires that they want to move. That does not always mean those tires are the best tires for your money and or your vehicle. Saving a buck or two when fitting tires can actually cost you more in the long run if you don't go with a good LRR tire. Also, anytime new tires are installed, traditionally the MPG will be lower until those tires are broken in. It varies the amount of miles to break in a set, but usually the MPG will improve after 3 to 6 thousand miles.
    Last but not least, if you are not using "Synthetic Oil" AND your car is NOT using or burning oil then change over to a good synthetic oil. Mobil 1 is what I recommend for the Gen II Prius. 5W-30 is what you need. Remember 3.9 quarts maximum with a filter change. Anything over that is over full. Check the dipstick level. If it is over the top dimple, you have too much oil in it. It is not a good idea to run excess oil in the Prius engine.
    One other thing that might help you would be to change the inverter coolant and also make sure that the spark plugs were changed at 120K. Also make sure they are the correct Iridium plugs.
    All of the things above will help to improve your gas mileage. If you want your car to last another 100,000 miles you will definitely need to maintain it very well. Don't be surprised if you have to work on the traction battery soon. Your pack is a minimum of nine years old, with over 150K on it. By all standards the pack is out of warranty. Some folks make it to 250 or 300 with no battery problems. Others don't. It would not surprise me to learn that your modules are getting weak at this time.
    I wish you the best of luck Emily.
    Ron (dorunron)
  16. Mike500
    Mike500 Senior Member
    2,593
    764
  17. dorunron
    3,318
    1,103
    Houston, TX
    Mike raised a very important point on the US models of the Prius. The fuel pump/filter is inside the tank which is a sealed unit. There is no access to the inner mechanism. It is rather expensive and somewhat labor intensive to change the tank. So do be aware of that.
    I would not worry about any of these things. Just handle whatever needs to be handled as time passes by. If you keep her maintained properly, and repair things as they break the car should continue to operate normally. The main thing is whether the cost of repairs are justified as some repairs can get a little pricy. But are not all vehicles like this at some point in their life?
    Best of luck to you,
    Ron
  18. usnavystgc
    3,159
    989
    Tucson, AZ
    Emily,
    I have changed transmission fluid in my 05 after 150,000 miles. It didn't cause any problems whatsoever and it really needed it. I highly recommend you change your tranny fluid ASAP.
    Silver Pine Mica and Britprius like this.
  19. scotty80
    scotty80 Junior Member
    I changed my transmission fluid after 150,000 miles also, it was quite dark. No change in anything afterward. The previous owner went to the dealer for all maintenance, so I was surprised that it still looked like the original oil. I bought the car at 148,000, did the change around 158,000.
    Silver Pine Mica and usnavystgc like this.
  20. Longinus876
    Longinus876 Junior Member
    89
    Long Island
    Yes, the tire pressure and rolling resistance are very important. 3-pound reduction in pressure will drop mileage considerably. But I have seen something else. That's too much of a drop. After getting my car back from Toyota, I was getting 36 mpg. I pulled the air cleaner out and thought I heard a slight pop. The filter was clean so I replaced. Then the mileage went to 46 mpg. I suspect the component located in that area. I think the mass air flow sensor is located right there, and I'm not sure if there's a throttle position sensor. This has happened 2 or 3 times with taking the car to the dealer. I have some suspicion that monkey business is going on. Who knows?
    #20 Longinus876, Oct 23, 2017
