Changing water pump - do I need to drain all the coolant?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Used2010Prius, Feb 2, 2024.
  1. Used2010Prius
    Used2010Prius New Member
    Los Angeles
    I want to change the water pump and thermostat on my 2010 Prius. In the YouTube videos I have seen, most people drain all the coolant before removing the water pump and thermostat. Do I need to drain all the coolant out? Or can I just drain some of it (like, for example 1 gallon, etc.)?
    I ask because the Toyota coolant is like $30 a gallon and I think I need 2 gallons ($60) to refill the coolant if I drain it all out. Also, I had just added like 3/4 of a gallon of a coolant recently (did not realize that the problem at the time was a failing water pump), so it would be nice if that didn't all just get drained and thrown away ($$$).
  2. Tombukt2
    Tombukt2 Senior Member
    12,215
    2,155
    Durham NC
    18 at Walmart Asian red works perfectly labeled as ok for Prius. Coolant wears out ya know!
  3. ASRDogman
    ASRDogman Senior Member
    7,243
    3,781
    Use a clean container and drain the fluid from the radiator and refill with it.
    You'll have to add some new coolant probably.
    You should only use the Toyota coolant. Even if any other says it okay for Toyota,
    it doesn't mean it is. It may turn the coolant into a jell.
    And the cost difference in extremely minor.
    Pour slowly, very slowly, a little at a time. You can hear it bubbling in the engine.
    And fill to the "B" line. Start normally, and wait until the engine shuts off, then check the coolant
    level. It's probably at the full line, or close. Add some if you need to. Then drive the car close
    to home for a few miles to get it up to temperature. Then park on level ground and clean up.
    Check the level in the tank, it should be at the full mark, or just above.
  4. ChapmanF
    17,349
    These steps are a little different in the repair manual: after filling to the B line, they have you start in maintenance mode, so the engine doesn't shut off early. You want to let it keep running until it is fully warmed to thermostat-opening temperature and coolant is flowing everywhere (the bottom radiator hose becomes hot, or you see the cooling fans come on, or you read at least 85–95℃ (185–205℉) on an OBD reader). Then let it run that way several minutes more.
    Then turn it off and let it all cool down. The level should end up at the full line (or very close) when it is all back to room temperature.
    Without using maintenance mode, the engine is likely to start, run just up to a minimal operating temperature, and say "hey, I'm a Prius" and turn off. That can be too early to get all the air out.
  5. Mendel Leisk
    40,586
    Info regarding coolant change and maintenance mode:
  6. CR94
    CR94 Senior Member
    2,664
    1,152
    Northwestern S.C.
    Which offers the comically misplaced "HINT" that the block drain "plug is on the back of the generator on the exhaust manifold side."
    What generator? In a Prius?
  7. Mendel Leisk
    40,586
    That reminds me: I would not bother with that block drain; it’s a pain to get to, and yields literally a few tablespoons.
