ChapmanF or other: I need help with no start - Jon in Hartford CT
Discussion in 'Gen 2 Prius Main Forum' started by swing, Oct 8, 2023.
  1. swing
    swing Junior Member
    81
    17
    CT
    Hi - 2007 Prius here - 300kmiles orig inverter, motor, trans, etc.
    > Car was parked with HV pack removed for 15 months (with 12v battery maintained at 12.9 volts).
    > Finally found time/$ to get a fresh pack, and install yesterday. But now that everythings back together, car isnt reacting or "clicking " on when i press the round START button......Headlites work, interior light works....beeps when fob inserted...but no radio...no dash...and no led green or orange comes on when i press the start button.
    Tried jump pack to be sure it wasnt the 12v batt.
    All fuses are good - fusible link block is good - 12battery is good....fresh hv pack is delivering 230v
    I dont have Techstream, but I do have a Scanguage II (but im not sure how to config it to scan for codes.
    Just wondering what would prevent the round START button from even entering the ACC led-mode? Can my Scangauge II do a proper code reading (if you need that first?).....or is there something simple im missing that I can check first before I do that? Im happy to make a video and/or describe in more elaborate detail what happens when I try to start it (but i basically covered it here i think) --- PS Everything worked when i removed the HV pack before summer of 2022....
    #1 swing, Oct 8, 2023
    49,523
    did you complete the third step of the orange safety interlock?
  3. swing
    swing Junior Member
    81
    17
    CT
    orange safety-interlock is IN place and properly engaged. (but according to this video, it doesnt seem the HV pack is actually needed for the car to turn on!).
    #2 swing, Oct 8, 2023
    Tombukt2 likes this.
    49,523
    what voltage reading do you get at the jump point under the hood?
  5. swing
    swing Junior Member
    81
    17
    CT
    12.23 at the battery posts in rear....12.19 at fusebox up front....im gonna trickle it overnight at 2 amps and see if that changes the reaction....but seems odd that it wouldnt come on when the 14.5 volt Lithium jump-pack was attached....battery is just a few years old.... I will try again tomorrow to see if higher 12v battery state changes things.
    #4 swing, Oct 8, 2023
  6. mr_guy_mann
    mr_guy_mann Senior Member
    3,483
    1,587
    NJ-USA
    SKS car or not? Fob in the dash slot or not? Do you see a "key" icon or "door open" icon on the dashboard?
    Check all fuses on the car - esp the AM2 fuse. If the inverter coolant pump shorted (it can happen) then it'll pop that fuse and the car will be "dead" as far as power button.
    I do not think that Scangauge has the capability to scan most systems on your Gen2. Here's a scantool review thread - some can do codes and data on all systems. (The Autel AP200 is decent "all around" tool if you don't need fancier functions).
    Once you have a capable scantool, see what systems respond - 4 or 5 systems should communicate even if the car is "off" (may have to cycle the hazard flashers and/or the door open-closed to wake up the BCM).
    https://priuschat.com/index.php?posts/3290690
    #5 mr_guy_mann, Oct 9, 2023
  7. Tombukt2
    Tombukt2 Senior Member
    9,220
    1,618
    Durham NC
    It's not I have the HV battery completely disconnected in a car right now and I have all the dash lights on and everything in the car works of course you're not going anywhere but that's not the point. Does your car ready or do you have a display gas gauge and the zero is on?
  8. swing
    swing Junior Member
    81
    17
    CT
    >> 12.6 ...but even with jump pack attached and reading 13.2V......nothing happens when i press START button
  9. swing
    swing Junior Member
    81
    17
    CT
    >>> car does not "Ready"....no sound, no clicks, no lights, no LED shows on the round START button - nothing. (just continues "beeping" when fob is inserted)
  10. swing
    swing Junior Member
    81
    17
    CT
    (SKS car/fob - fob battery may be low or dead)
    Left of dash shows red "Door Open" led light (because door/s are open. > is it ok to attempt start with door/s open?)
    Right of dash shows red-flashing car"KEY" light
    When fob is inserted key-beeping starts
    interior light is on and bright
    headlights turn on when manually engaged on stalk
    >> Press round START button: no clicks, no led lights on button, no dash, no display, no radio
    ,....no change
    System at 12.7 v nominal and at 13.5 volts with jump pack enacted.....still no change.
    AM2 and all fuses good in front hood fusebox....good pink coolant levels
    I have not checked under-dash fuses....
    Is there a flow chart that shows what the computer "looks for" before allowing the car contatcors to engage into READY mode?
    SHort of calling a tow truck to take it to a Teschstream dealer and pay $$$ - whats a good Scan device at retail (Harbor Freight? AutoZone? Amazon?) that could help me?
    I guess its possible corrosion set in on the ECU molex connectors - I could try re-seating those?
    or maybe mice?
    Final note (that should not affect this): the heads up flouro display was starting to go bad before this process...but the car always started immediately when the round button was pressed....even on mornings with a "black display"....so i dont think? that further degradation of the caps in that assembly would now prevent READY state all of a sudden....
    #9 swing, Oct 9, 2023
  11. Mendel Leisk
    38,753
    Just to invoke the "bat signal", paging @ChapmanF
  12. Mendel Leisk
    38,753
    Got a double post, just doing a page refresh... :confused:
  13. swing
    swing Junior Member
    81
    17
    CT
    Thanks so much - didnt know how to do that!%
  14. ChapmanF
    15,704
    Not a situation I've dealt with before. I would just have my nose in the repair manual, around the troubleshooting steps in the "1NZ-FXE STARTING - SMART KEY SYSTEM" section. There is a problem symptoms table there, with a bunch of ideas, some of which mr_guy_mann has already mentioned.
    I also seem to remember some way was described to awaken a few of the ECUs for diagnostics with the main power off, as mr_guy_mann describes. Sounds like he's probably got more experience with that.
    swing likes this.
  15. swing
    swing Junior Member
    81
    17
    CT
    Much appreciated thoughts, Chap. Thanks - this seems to be the Smartkey Gen 2 flowchart youre referring to?
    https://attachments.priuschat.com/attachment-files/2020/01/180104_ST_-_1NZ-FXE_Starting.pdf
  16. swing
    swing Junior Member
    81
    17
    CT
    Guy - would you mind a phone call with a couple confidence-check questions - im thinking my next step seems to be to get the AP200 & app, so i can properly read the codes and follow the diagnostic steps in the ignition-pages......
    after 11am. - im at 203-910-7903 - Jon March
  17. rjparker
    rjparker Tu Humilde Sirviente
    8,003
    4,742
    Texas Hill Country
    Sounds like a bad combination meter. Pretty common.
  18. swing
    swing Junior Member
    81
    17
    CT
    well, i was having combo meter blackouts when i put the car up on blocks 16 onths ago....but even when the meter was pitch black, the car always started. (to shut it down requiored 2 presses of the Start/Off button)
    If the combo display gets worse than just "intermittent,".....does that eventually stop the ECU from starting the car at all??
    Jon
  19. rjparker
    8,003
    4,742
    Texas Hill Country
    Normally no but you have dismissed most other issues and can't see a check engine or other warnings. I would get Techstream on it. Otherwise you are guessing and want others to do the same. Often troubleshooting goes bad when we assume a step is good and never retrace our steps.
    Fresh meaning new? Modules replaced by who? How are you measuring 230v? The orange disconnect has been "engaged" by others without realizing a final slide is required.
    I thought all fuses were checked. A common issue is pulling fuses and getting one put back in the wrong place. It may then blow or an empty place is not supplying power.
  20. swing
    swing Junior Member
    81
    17
    CT
    (FYI: My goal asking here, was to avoid what happened in this similar-issue thread with Techstream: )
    2007 Prius wont start, no response, new 12 v installed. | PriusChat
    (re: combo display lights being capracitor-deprecated/black & possibly? preventing IGN.):
    Normally no, but you have dismissed most other issues and can't see a check engine or other warnings.
    Most issues not dismissed: biggest ones all checked...voltage was checked, all engine compartment fuses checked and replaced correctly, possibility of oxidized pin connections suggested as well as mice.
    Secondary issues now being addressed with upcoming Autel scan
    That would require a costly tow to a more costly dealer, no?.
    ....others suggested a DIY scan with an Autel AP200 & follow codes in IGN process manual - im leaning to that.
    Yes - but only in hopes it was something off the top of experienced peoples heads who know far more than me. Not asking for miracles, just some possibilities to check without going scorched earth towing to a dealer.
    Agree, which is why im not assuming anything, just asking for possibilities aside from an intelligent scan on a dead car that wont power up!
    New Nexgen V2 lithium cells - 100% balanced and installed with all new copper harnesses and nickel fasteners
    Fluke DVM - on the supply-side of the traction battery output contactor solenoid posts
    Nope - fully engaged by me...properly!
    Engine compartment fuses were checked...underdash ones I relays will be checked today.
    Tested in circuit - not pulled - all are showing 12v on both sides of fuse and on bussbar
    #18 swing, Oct 10, 2023
  21. ChapmanF
    15,704
    We had one thread here where somebody carefully took a picture of the fusebox with a phone, took the fuses out, tested them, and put them all back in exactly where the phone picture showed ...
    ... having used the phone in selfie mode, and the photo got saved in mirror-image, the way you see it in selfie mode.
  22. swing
    swing Junior Member
    81
    17
    CT
    LOL - I can see that happening! - Im not perfect, but im pretty vigilant about pics & documentation !
    JON
