Charge connector release issue
Discussion in 'Prime Main Forum (2017-2022)' started by ppongi, Jul 15, 2021.
  1. ppongi
    ppongi Junior Member
    42
    Allen, Texas
    I have a 2017 PP premium model with about 46k miles on odometer. I started noticing a significant delay in the release of the charge connector during the charge. I found the metal thingy at the top would not go back and hold the connector so I have to squeeze the lever for about 30 seconds to release the charge connector. The other day, I had to stand in the rain for about 30 seconds trying to release the charger from a public charging station. Definitely not the charger issue as it does the same thing at my house. Does anyone have this annoying problem?
  2. ForestBeekeeper
    ForestBeekeeper Active Member
    706
    276
    Maine
    I have not seen that issue, yet.
    I wonder if the release / docking clamp mechanism is likely powered by the 12vdc battery, I have had 12vdc battery issues in the past. When that happens there are weird problems everywhere. I bet the mechanism is not getting enough current from the 12vdc battery.
    Trollbait and Salamander_King like this.
  3. ppongi
    42
    Allen, Texas
    I have not thought about 12v battery could impact or regulate the charging or release mechanism in particular. I guess it’s possible though.
    49,492
    why didn't they just leave it manual like the pip
  5. pghyndman
    pghyndman Active Member
    498
    465
    CT shoreline
    To allow it to be "locked" against tampering or unauthorized disconnection (can be "locked" and limited model requires key fob proximity to release... I never lock mine, but can do so if desired).
    jerrymildred and bisco like this.
  6. EdPalmer42
    EdPalmer42 Member
    121
    65
    2020 Prius Prime
    I don't have the problem, or the locking connector, but is it possible that the 4-5 year old mechanism is starting to get gummed up? Maybe squirt some cleaner/solvent into it.
  7. dig4dirt
    dig4dirt MoonGlow
    1,150
    741
    Lancaster Co PA
    2014 Prius c
    Could your FOB battery be getting low?
  8. ppongi
    42
    Allen, Texas
    No visible gunk or gummed up metal thingy when it is exposed to view biting the charger. And, I don’t lock it when I charge inside my garage.
    Replaced key fob battery a few months ago so I’m pretty sure the problem has nothing to do with it.
