Charge mode while speeding/maybe worth it?
Discussion in 'Prime Main Forum (2017-2022)' started by Markelli, Jun 14, 2022.
  1. Markelli
    Markelli Junior Member
    50
    South Florida
    So there is an express lane that bypasses the highway, I go about 88mph in a 80 zone. It’s mostly clear with plenty of room. During my commute everyone is going much faster on it and treat it like the autobahn. So I started using charge mode, my logic here is the 88mph I’m going is already killing the mpg so might as well charge up while doing it. Is charge mode really causing mpg damage while you’re already speeding? I haven’t noticed my mpg change whether in charge mode or not. The speeding seems to eat the mpg either way. Any thoughts?
    51,155
    i think you would have to do some controlled testing, but you may be on to something.
    i assume charge mode puts an extra lode on the engine, but how much at those rpm's is a great question.
    something like scan gauge measuring rpm's and mpg's would be helpful.
  3. ForestBeekeeper
    ForestBeekeeper Active Member
    766
    302
    Maine
    Whenever our charge drops low enough that the ICE kicks on, we always start CHG'ing.
    If you remember years ago on MythBusters they tested vehicle mileage with windows open and with A/C running. What they found was the extra drag on the engine caused by the A/C had no effect on mileage. Yes it is an extra drag, but it is so tiny that they could not detect it. On the other hand, windows being open causes so much turbulence that it did hurt mileage.
    The ICE generates electricity, putting some of that electricity into the battery does not harm mileage.
    Roughly 30-miles of driving while CHG'ing gives us 15-miles of EV range.
    51,155
    i think you're incorrect, but neither of us has data
  5. Markelli
    50
    South Florida
    So far i’ve not noticed a difference between my 49.8 mpg whether on charge mode or just hv but at the end I have a good 6 miles stored up in electric but it’s not the most scientific analysis. For me the extra speed just gets me home faster like maybe by 15 minutes. I was already doing it but now I get a bonus that I use as soon as I get off and hit lights etc I’m in ev mode for 6 miles which raises my mpg a partly .8 or maybe 1 mpg but it’s better than before when I got nothing at high rpm’s..
    ForestBeekeeper likes this.
  6. Salamander_King
    Salamander_King Senior Member
    11,009
    8,935
    New England
    We have discussed this topic before. Here is the link.
    Can using CHG Mode be more efficient?
    While I have never tested your scenario of driving 88mph with CHG mode, at moderate speed up to 65mph or so, CHG mode + using EV mode from the traction battery charged during CHG mode offers neither benefit nor penalty on the overall mpg when compared to driving the same distance with HV mode only in the same condition. Your mileage may vary depending on a lot of factors, so there can be a case that using CHG mode and utilizing the traction battery charge for EV mode later may make sense.
    However, one good reason not to abuse the CHG mode is that it is akin to using DC Fast charging on the traction battery. You may be shortening the life of the traction battery by repeatedly using CHG mode. Remember that the PP has no active cooling mechanism other than just taking AC air from the cabin. You are generating a lot of heat during the CHG mode.
    #6 Salamander_King, Jun 14, 2022
  7. Markelli
    50
    South Florida
    Well 88mph was fast enough for a Delorian to go back in time just need a flux capacitor. But I’m guessing anything after 85 mph is already destroying mpg and turning on charge mode doesn’t really matter at that point?
  8. Salamander_King
    11,009
    8,935
    New England
    At sustained speed above 72mph, the PP normally neither charges nor discharges the traction battery. I have shown that fact in this thread.
    Engine only MPG
    Now, if you are driving at a sustained speed of 88mph and force the CHG mode to engage in charging the traction battery. That extra energy has to come from somewhere. You may not be seeing an mpg difference with or without CHG mode in your few cases, but I am almost certain that the extra load required to charge the traction battery must have reduced the overall efficiency. You are just not seeing it because it is buried under lots of noise from many variables.
    mountaineer likes this.
  9. bisco
    51,155
    if charge mode didn't hurt mpg, there would have to be another reason toyota didn't implement it permanently in the software management. that could be sal's charging rate scenario above.
  10. Markelli
    50
    South Florida
    I believe the high rpm’s and engine load has energy to spare similar to say a regular car when braking doesn’t regenerate energy. Since your mpg savings are gone at high speeds like this I’m not sure the engine is working any harder or under any extra burden at least at 85+ mph
  11. Markelli
    50
    South Florida
    I’m thinking Toyota assumed correctly 99.99% of owners won’t be driving at almost 90mph lol also liability reasons they can’t have a feature for people that are blowing any mpg savings speeding. This is just an unusual thing I discovered..
  12. bisco
    51,155
    i didn't mean that, i meant all the time.
  13. Markelli
    50
    South Florida
    Well I believe that charge mode really isn’t worth it but I may have stumbled on a moment when it doesn’t matter, such as blowing eco driving and mpg savings could be a time when charge mode actually gives a bonus
  14. bisco
    51,155
    it would be nice to see one go through the epa testing, with and without.
  15. Markelli
    50
    South Florida
    This is a tricky one as you really can’t test something that’s illegal i.e speeding
  16. Salamander_King
    11,009
    8,935
    New England
    Well, if you are comfortable with the idea of getting a free lunch in exchange for a much more costly early traction battery replacement, then enjoy your lunch. ;)
  17. bisco
    51,155
    yeah, and the epa test is all at normal driving speeds. but it would be nice to know in those situations as well.
    might be worth using charge mode more. or not.
  18. Markelli
    50
    South Florida
    I’m not sure the charge feature damages the traction battery as it’s not a hack it’s an official mode the car can be put in to use the ICE to charge the battery while driving. If that was true, why would they even have that feature?
  19. bisco
    51,155
    is there a warning in the manual?
    it might be worth monitoring battery temps
  20. Salamander_King
    11,009
    8,935
    New England
    Was there a warning in the manual for early Leaf for using a Fast DC charge too frequently is detrimental to the longevity of the traction battery? At least, Toyota warrants the battery for 10 years 150kmiles, as long as it is not just degradation.
    I wonder if anyone has actually measured the traction battery temperature during CHG mode? If it is not substantially higher than the high temperature during L2 charge session, it may be fine.
