Charge Port Leaks
Discussion in 'Prime Main Forum (2017-2022)' started by Solar Powered Prime, Feb 12, 2019.
  1. Solar Powered Prime
    Solar Powered Prime Junior Member
    Pittsburgh
    2018 Prius Prime
    We live in an area with record rainfall. Not sure if it was intended but the cover door to the charge port almost always has a lot of water around it. Does everyone have this problem? We took it to the dealer and they said that is the way it was designed (no seal around the cover). I am not worried about water getting in to the charge port itself, but am a bit surprised that it might cause a rust problem.
  2. schja01
    schja01 Senior Member
    1,820
    1,207
    Chicagoland
    2024 Prius
    Limited AWD-e
    I never saw water after going through a car wash.
  3. Bob Comer
    Bob Comer Active Member
    708
    460
    South Carolina low country
    I also live in an area with lots of rain, and yes, water gets in the charge port door all the time. As long as you put the cap on the charge port itself, I don't think we'll have rust problems, most of it's plastic and what isn't looks like the same paint treatment as the outside of the car.
    Solar Powered Prime likes this.
  4. Pdog808
    Pdog808 Active Member
    427
    284
    Los Angeles
    2018 Prius Prime
    I don't think you want to seal around the chargeport cover (assuming you are talking about the hatch that pops open). Otherwise, when you charge when it rains, the water inside the cover would never dry out. You would definitely have rusting issues then.
  5. john1701a
    john1701a Prius Guru
    12,797
    5,279
    57
    It is designed to drain, since charging while it rains & snows with the door open is a normal function. It will get wet inside. No harm.
  6. Solar Powered Prime
    Pittsburgh
    2018 Prius Prime
    Thanks, but trust me, it never seems to dry out. We always park in a garage, so the rain gets in during day, but just sits there.
  7. Pdog808
    427
    284
    Los Angeles
    2018 Prius Prime
    Yeah, even in Southern Cal, it takes a few days to dry out. I would assume that with a higher humidity, it would take a lot longer. Remember, water gets in underneath your car and in all the crevices during normal drying and these take just as long to dry out.
  8. bisco
    51,140
    i think someone one else came up with a gasket seal in another thread. i wouldn't be happy if water was sitting in mine.
  9. john1701a
    12,797
    5,279
    57
    Why? It's not a problem and a seal would mean never charging if there is even a remote chance of precipitation. Giving that up makes no sense.
    Again, it is designed to deal with water.
  10. bisco
    51,140
    mine is garaged
  11. john1701a
    12,797
    5,279
    57
    You never wash your car?
  12. bisco
    51,140
    never :oops: rain gets most of it clean, except the rear end seems to attract dirt
    heiwa likes this.
  13. Lee Jay
    Lee Jay Senior Member
    5,850
    4,030
    Westminster, Colorado
    It's not even supposed to seal. Think about charging in the rain or snow - the door is completely open. Everything inside is designed to handle water, including the electrical connector.
    benagi likes this.
