Charge State Display
Discussion in 'Gen 2 Prius Fuel Economy' started by Bob_Stan, Jan 17, 2012.
  1. Bob_Stan
    Bob_Stan New Member
    70
    Central New York
    It may just be selective memory on my part, but the battery charge indicator on my 2009 Prius seems to be staying full green most of the time. I thought in the past it was mainly in the blue, unless I had descended a long hill. Also, when I am accelerating going up a steep hill, the MFD shows the battery charging even though it is 8 bars. Is this normal? I have had it checked by the dealer and they say everything is normal.
    52,100
    yeah, all green all the time? doesn't seem right. mine only goes green after pronged glides or some types of highway driving.
  3. Bob_Stan
    Bob_Stan New Member
    70
    Central New York
    It isn't that it is always green. When driving on level ground in the 40 to 50 mph range like thorugh town, it will dip into the blue for a while, but very seldom.
  4. MJFrog
    MJFrog Active Member
    780
    267
    NE Oklahoma
    2018 Nissan LEAF
    How's your MPG? Is it dropping...more so than winter weather accounts for?
    It might be time to check your 12v battery for replacement.
  5. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Eight green bars most of the time is very unusual, but 7 green bar not so uncommon, especially when the engine is running a lot to maintain heat in winter.
    BTW. Many people report 8 green bars when there's actually only 7.
  6. Bob_Stan
    Bob_Stan New Member
    70
    Central New York
    It is possible that I am miscounting the bars, but historically on my average drives I get 49-52 mpg in the summer and 42 to 48 in the winter. Now I am getting 38 to 42, although it has been cold recently. The point has become moot though, as I just traded it in on a 2011 blizzard pearl Prius.
  7. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    In summer you only run the engine when you need charge or you need to go somewhere.
    In winter you also run the engine to heat the cabin, but a byproduct of that is 'spare' electricity, so the computers put it in your battery until they can dissipate it.
  8. bisco
    52,100
    i hope you disclosed your 'problem' to them.:rolleyes:
  9. Bob_Stan
    Bob_Stan New Member
    70
    Central New York
    I trraded it in to the same dealership that does ALL the service on my vehicle so they have a complete service history. In fact, at the last service (300 miles ago) I specifically asked that they check out the issue and they reported everything was fine.
    I just finished running the procedures detailed in this forum to check the 12 volt battery and find that it is at 11.4 volts so I believe that is the source of the problem. Why they didn't find the same thing during the last service is a mystery.
  10. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    I see this frequently in winter, and sometimes on the highway where the ICE has to run continuously.
    Tom
  11. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Good question, it's amazing how often people report issues involving low 12V battery voltages but the dealer never finds the problem. I think in most case they don't do anything other than check for codes. No code then no problem found.
  12. navguy12
    navguy12 Member
    193
    32
    Batawa Ontario
    Trading my '07 HCH for an '08 Prius. Based on this quote, does the Prius software 'force an impromptu' balance of the cels as a normal state of affairs? Only reason I ask: with issues with the Civic IMA battery, I always thought that there should have been some sort of gentle but forced low amp charge just to keep the cels balanced. Or am i reading too much into this.
    Signed: 4 days until delivery and counting:)
