Charge takes longer than listed
Discussion in 'Prime Plug-in Charging' started by JeremyM09, Jul 5, 2019.
  1. JeremyM09
    JeremyM09 Junior Member
    Ohio
    2020 Prius Prime
    Just got my 2020 Prius Prime LE on Monday.
    I'm charged on a regular 110v outlet in my garage. We had the house rewired less than 2 years ago, so I know this outlet is on a 20 amp GFCI breaker. The rest of the breaker is some empty outlets, the garage lights and garage door openers. Lights are almost never on, garage door opener is used a couple times a day.
    When I plug it in when the battery is depleted I've seen it say as long as 6 hours, 10 minutes even though it's listed to be 5 hours 10 minutes.
    Any ideas on what I can try to change? I know that nothing else is drawing power except as listed above. Because the garage is detached and separated from the house with a concrete driveway I don't see running 240v as being easy.
  2. jb in NE
    jb in NE Senior Member
    2,233
    1,596
    Nebraska
    2018 Prius Prime
    What is the actual (not estimated) time to a full charge? I wouldn’t change anything - just let the car charge itself.
    Rob43 likes this.
  3. fuzzy1
    10,170
    Have you measured the actual voltage at the outlet? If it is on the low end of normal, it will take longer.
    Voltage can be high or low depending on what the utility has set, how long and resistive the wires are (both on the utility side and on your side of the meter), other loads on the same system, etc.
  4. Prius from Dad
    Prius from Dad Senior Member
    724
    1,115
    Toms River, NJ USA
    Your settings are probably set to 8A (I believe it is the default) Follow the instructions on page 123 of the Prime manual to change it to 12A.
    Use the following to change from 8A to 12A
    Page 123
    Arctic_White and jerrymildred like this.
  5. Tha_Ape
    Tha_Ape Active Member
    271
    161
    Washington, DC
    Mine says 5:50 to fill on a totally drained battery, 2:10 on 240V
  6. jb in NE
    2,233
    1,596
    Nebraska
    2018 Prius Prime
    I would be surprised if this would result in a charge time of about 6 hours. At 8 amps it should be about 9 hours.
    fuzzy1 and Raytheeagle like this.
  7. Rob43
    Rob43 Senior Member
    1,373
    1,047
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    OP,
    This is your answer.
    Test this, then report back...
    Rob43
  8. Bejeffer
    Bejeffer Junior Member
    Atlanta
    2018 Prius Prime
    Recently mine went to 6 hr to fully charge. Used to consistently be 5 hr.40 min. May be due to temperature (?)....its been really hot in Atlanta since May
    AAA likes this.
  9. bisco
    49,492
    most likely
    Rob43 likes this.
  10. Rob43
    Rob43 Senior Member
    1,373
    1,047
    2013 Prius v wagon
    Hot batteries have greater resistance & take longer to charge.
    Rob43
    PS, if you have any type of 240v receptacle near your Prime, you can use your OE Toyota EVSE and charge up in about 2 1/2 hours.
  11. Salamander_King
    Salamander_King Senior Member
    10,975
    8,867
    New England
    Mine is on 20A with freezer in the garage. The has always said "6 hours 10 min" to full when plugged in with zero EV range left, but it actually takes only 5 hours 20-30min to complete. I have never plugged into a different outlet, so I don't know if it will say any different estimate.
  12. jb in NE
    2,233
    1,596
    Nebraska
    2018 Prius Prime
    Do you charge immediately after driving, or on a delayed schedule for the middle of the night when the air and your battery are cooler? Do you enable traction battery cooling?
    And, is this the actual charge time or the estimated?
    #12 jb in NE, Jul 14, 2019
  13. Bejeffer
    Atlanta
    2018 Prius Prime
    I normally charge during the day as soon as I get in; most days b4 3pm. It is the actual time it takes....I get the email notifier when completed. I plead ignorant regarding "traction battery cooling"; I've seen the message on the dash and just ignored it. (Still haven't read manual ). But..... I haven't really driven it that much (I'm retired) , less than 9K on it after 1.5 years.
  14. cyn
    cyn Junior Member
    san diego
    My 2017 Prime went from consistently 5 hours 40 minutes to 13 hours 20 minute to full charge in the past week. It’s currently at Toyota service now; not sure if they will be able to find anything constructive as their last phone call was to tell me everything was fine, it wasn’t charging due to the “setting” not set to charge it now.
    AAA likes this.
  15. Rob43
    Rob43 Senior Member
    1,373
    1,047
    2013 Prius v wagon
    Welcome to PriusChat.
    Please keep us up to date on this.
    Rob43
  16. Blauer Glimmer
    Blauer Glimmer Active Member
    448
    169
    NY (Southern Tier)
    I'm guessing the "setting" they are referring to is the maximum charging current. Somehow, your setting may have changed from 12A to 8A, which is much slower.
  17. fuzzy1
    10,170
    But it shouldn't be anywhere near that much slower.
  18. Blauer Glimmer
    448
    169
    NY (Southern Tier)
    True
  19. stevegoldfield
    stevegoldfield Junior Member
    Oakland, CA
    I also have a 2017 Prius Prime that I bought in 2018. Since I bought it, a full charge has taken 2 hours (with a 240V, 30 amp charger). However, yesterday for the first time, it took 2 hours and 30 minutes. It isn't the temperature; it hasn't changed much and it almost never goes as low as freezing here. Today, I didn't need a full charge, but it said it would need 2 hours and 20 minutes; it should have been about 1 hour and 50 minutes. It's weird that it would change from one day to the next; it was fine on Wednesday, i.e., for 4 years.
  20. sergio77
    sergio77 New Member
    US
    2013 Nissan LEAF
    I also contacted the service center, they changed some settings. Now I want to figure it out myself.
