Charge time for Enginer system - 110V versus 220V
Discussion in 'Prius PHEV Plug-In Modifications' started by SFGiant-and-Plugin-Fan, Feb 21, 2011.
  1. SFGiant-and-Plugin-Fan
    47
    Durham, NC
    The Enginer install manual says that the charger's average current is "10A @120VAC or 5A @220VAC" and that "it takes about 5 hours to charge up from drained." No indication is given that there is a different charge time for 110V versus 220V. Does this mean that the system is set up to charge at the same rate, regardless of which outlet is being used?:confused:
  2. ericbecky
    ericbecky Hybrid Battery Hero
    4,369
    3,217
    Madison, Wisconsin
    Do you have your system set up to charge 220?
  3. Floyd2
    Floyd2 progressio per sententia
    106
    23
    Netherlands, Europe
    On average the US grid provides 115 Volts AC and in Europe 230 Volts. The charger has a slide switch marked 115 - 230.
    US: 115V x 10A = 1.15 kiloWatts maximum per hour.
    Europe: 230V x 5A = 1.15 kiloWatts maximum per hour.
    So the charging time will be about the same, no matter where you live. My experience is that the pack depletes up to about 3.7 kWh and recharging takes about 4 hours.
    In NC that will take about the same time but never set your charger to 230V if you use a US 115V outlet.
  4. SFGiant-and-Plugin-Fan
    47
    Durham, NC
    Thanks. I have not installed the system, but was being advised to set it up so that I could go either way under the assumption that charging via higher voltage would take less time. Since this does not seem to be the case, I'm not going to bother with the higher voltage option and will keep it on 110V.
  5. Flaninacupboard
    Flaninacupboard Senior Member
    1,297
    213
    Midlands - UK
    Charging at 230v will be slightly more efficient, but the hassle of not being able to plug in anyhwere may make it not worth doing for you.
  6. SFGiant-and-Plugin-Fan
    47
    Durham, NC
    I mean, I will keep it on 115V. :rolleyes:
  7. Floyd2
    106
    23
    Netherlands, Europe
    You may very well have 110V, it varies slightly from state to state. Same goes for Europe: Flaninacupboard probably uses 240V in the UK and I have 220V in the Netherlands. So let's call it 230V. ;)
  8. pcwulf
    pcwulf Junior Member
    Mainland Europe
    Hi Floyd2,
    I live in Netherlands and trying to find some information regarding converting my Gen-II to PHEV. Came across your post and thought of asking some questions.
    Once you convert a car to PHEV in NL, is it possible to register it with the motorvehicle registration as a PHEV. (Obvious reason for the question is that they offer and extension of the vehical tax exceptoin until 2019 for certain PHEVS)
    Further, can you share some information about how to do the conversion here in NL. Can I order the kit from enginer directly to NL? Or are there service providers here who'll do the conversion for you?
    Thanks in advance.
  9. lopezjm2001
    lopezjm2001 Senior Member
    1,146
    407
    Sydney Australia
    Hi PCwolf,
    Enginer has shutdown and gone bankrupt. There is a supplier of the same kit in Germany which sells by a different name i.e.MD-Tech which is supposed to be an improved version of the Enginer kit.
    See his website: PHEV kit System - Plug-in Autos
    steveinsaugus likes this.
