Charge Times @ home
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by fortytwok, Apr 13, 2013.
  1. fortytwok
    fortytwok Active Member
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    sorry if this was addressed elsewhere but
    I was considering a 240v install however once I started plugging in directly to the wall (120v)
    my charge time dropped well below whats been advertised. I'm getting fully charged from 0 in 2hrs 10 minutes. I don't think it makes financial sense to pony up $ to gain a half hour.
    Anyone else getting much better than the 3 hrs est time ?
  2. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    Average charge time from 120v source is usually around 2h45m starting w/a a fully depleted battery at above 32deg temps.
    Average charge time from 240v source is usually around 1h30m starting w/a a fully depleted battery at above 32deg temps.
    2h10m isn't normal for a full charge from empty on a 120v source.
    49,371
    not sure why we all experience different charge rates. i was pretty close to 3 hours on 120v, and am close to 1 1/2 hours on 240v. it's nice when i'm recharging several times a day. i wonder if you would recharge in 65 minutes on 240v?
    another thing is: what is zero? when you run out of ev, you start eating into the hv portion. so, you're always recharging from a different level. not huge, but some difference.
  4. fortytwok
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    when I said zero - I mean I ran out of EV and then started charging. I'm usually plugging in with the reading at 1.0 or less and I've been timing the charge rates. Its been consistently 5.8 per hour = 11.6 2hrs and "full" has been 12.5.
    Its been cold last month here but already finding that "full" has been increasing with warmer temps - 12.8 yesterday.
  5. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    It usually takes about 2 hrs and 20 minutes for a full charge for mine. My car is garaged, and the temperature doesn't seem to affect the charge time much. Of course, this is Ca., so garage temps are usually in the high forties and above.
  6. Gr8ful Ed
    Gr8ful Ed New Member
    I actually have been thinking of posting the same topic. I already have a 220 outlet in the garage, thanks to the previous owner being a welder, so it would be is to install a charging station. Is there any benefits, other than convenience, in installing a 220 unit.
  7. MK500
    MK500 Member
    92
    San Francisco, CA
    2013 Prius Plug-in
    I'm definitely "filling up" in less than 3 hours. I'd say average is more like 2.5 hours. And we quite often arrive home with less than 1 mile. Yesterday it was like .1 hehee. I'm probably still going to get the 240 because I want some of the other features of the openevse; and it's just a lot more convenient to leave the other cable in the trunk.
    My garage is in the low to mid 60's F all year long.
  8. ny_rob
    1,968
    813
    L.I.- NY
    240v charging is a few percent more efficient than 120v charging, but it's not enough of a difference to make it worth your while to upgrade just because of that. Faster charging time is the main advantage to 240v charging.
    FWIW- the bulk of the 240 charging is done in the first hour- then the current drops to less than half to finish up the full charge.
  9. fortytwok
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    Well I just got a pretty definitive answer.
    Tried a Chargepoint station for the first time. 240V and full charge rate was 83 minutes vs my 2:10 for home 120v. I say charge rate because I was low but not completely empty. It was filling up the same for the first 15 minutes as the next 15 minutes.
    SO for my 2013 PIP the 240V is as advertised maybe a bit better since they claim 90 minutes.
    The big surprise is the 2:10 in my home vs the 3 hr claim.
  10. iplug
    iplug Senior Member
    2,455
    1,703
    Rocklin, CA
    I get about the same as fortytwok - EV completely exhausted consistently takes 2:10-2:20 for a full charge.
  11. beovox
    beovox Junior Member
    Sweden
    2013 Prius Plug-in
    Hmm I think this is strange i do have 240v and the standard charging cord as for living in EU and should there for charge in 1 hour 30 min. But it always says 2.4 hours it looks done at one and a half hour if you look on the display the battery is at the top but its still charging with 0.5 kW instead of 1.8 kW that its charging with in the begining.
  12. bisco
    49,371
    yes, it slows way down as it fills up. you can get a lot of charging down in 1 1/2 - 2 hours. not really sure if the last .5 - 1.0 mile is worth the time if you need to go somewhere.
  13. Gr8ful Ed
    Thank you! Right now I am able to recharge in less than 3hrs. So i think for now may hold of on the 240. Maybe I will buy some all weather mats instead.
  14. fortytwok
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    Drove into Boston today and found a GE charge station at Whole Foods - perfect as it was halfway and I hit 0 just before arriving. Also completely free btw ! Did the right thing, bought coffee and read the paper while waiting
    Just posting this to point out the charge time was different from the Chargepoint Station.
    Took me 72 minutes vs 83 just a day prior - both Level 2 stations.
