ChargeNow fails to start when car has 17 miles
Discussion in 'Prime Main Forum (2017-2022)' started by Sid786, Dec 29, 2018.
  1. Sid786
    Sid786 Active Member
    262
    146
    Cherry Hill, NJ
    Sometimes when the car haa more than half charge remaining then it fails to charge automatically when connected to power cable. Even retrying multiple times from mobile app also fails to start charging. Is there a way to start the charge from car buttons.
  2. PT Guy
    PT Guy Senior Member
    1,085
    710
    Washington, the state
    Could the connector need a bit more nudge into the car's socket? I've found that. The last nudge, then the green light under the connector lights, the controller goes clickclick-click, and it's charging.
  3. Sid786
    262
    146
    Cherry Hill, NJ
    I am very much positive that in my case, it is not the connector, because after 15 or 20 minutes of waiting it starts by itself. I just wanted to start it right away.
    49,397
    could the battery heater be bringing it up to temp before charging starts?
  5. Sid786
    262
    146
    Cherry Hill, NJ
    That's definitely a plausible logic, if this is how the battery heater works. Another possibility is that it is cooling down the battery as it was in use.
  6. bisco
    49,397
    good point. can you shut off battery conditioning and try it?
  7. jerrymildred
    jerrymildred Senior Member
    11,508
    14,109
    Tampa, FL
    That would be my guess if you're plugging it in as soon as you get home, although I've never had that happen in the PiP.
  8. bisco
    49,397
    pip doesn't have active cooling
    or heating
    or conditioning
    jerrymildred likes this.
  9. jerrymildred
    11,508
    14,109
    Tampa, FL
    I was just referring to the delay in charging immediately after a drive. Nothing active. But you make a good point. An active system would ned time to do its thing before commencing with the charge.
