Charger/discharger who’s better?
Discussion in 'Gen 2 Prius Technical Discussion' started by Ianmeister, Nov 25, 2021.
  1. Ianmeister
    Ianmeister Active Member
    316
    318
    Meridian Idaho
    Hey all. I’m considering a charger/discharger reconditioning system. So which is better, Prolong or Max Volts?
    enquiring minds want to know.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    Prolong(y).
    SFO likes this.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,801
    2017 Prius c
    IF.....you still have the original HV battery in your 16 year old Prius, your money will be MUCH better spent saving for a new car.
    Seriously.
  4. Ianmeister
    316
    318
    Meridian Idaho
    why does everyone say this? This route isn’t fun, there’s no challenge, and you’re just buying the next car’s problems. A good used car will wear out eventually, a new car is saddled with absurd depreciation and interest plus the higher insurance. On top of that there’s no sense of accomplishment.
    good luck wasting money.
  5. Ianmeister
    316
    318
    Meridian Idaho
    Ah, ok, why is that?
  6. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    It appears you got a Thanksgiving treat from a member I have on ignore:cool:.
    Seems like an appropriate action so you can celebrate a holiday and not have some extreme negative comments to mull over;).
    As long as you are willing to undertake the maintenance yourself, a used Prius can be a valuable mode of transportation :).
    Happy Thanksgiving (y).
    Flyboy314 likes this.
  7. Ianmeister
    316
    318
    Meridian Idaho
    :D Pfft! Thanks Ray! I needed to hear something worthwhile. Happy TG to you and yours as well. So why is the Prolong better?
  8. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    For one, Maxx Volt only allows for charging and not discharging :whistle:.
    If you want to get the most out of a pack that is seasoned, you'll need to discharge it to break the "memory" of the cells;).
    The Prolong harness makes that task easy:).
    I had a similar decision to make back in 2017 and went with Prolong and these were some of the reasons (y).
  9. Ianmeister
    316
    318
    Meridian Idaho
    Maxx volt has a separate but compatible discharger now.
    https://www.maxx-volts.com/products/maxx-volts-pro-automatic-discharger
  10. alftoy
    alftoy Senior Member
    1,132
    516
    Saskatchewan, Canada
    #10 alftoy, Nov 25, 2021
  11. sam spade 2
    7,035
    2,801
    2017 Prius c
    Because when you are talking about trying to "rejuvenate" a 16 year old battery it is TRUE.
    And doing that IS undoubtedly wasting money because it does not WORK in any meaningful sense.
    AND it can be dangerous for someone with no skill or experience.......which some of your earlier posts tends to indicate is true.
    NOT a good idea. I quit.
    JohnPrius3005 likes this.
  12. sam spade 2
    7,035
    2,801
    2017 Prius c
    Don't confuse me with facts, my mind is already made up.
    If it doesn't conform to what you think is true, you don't want to hear it.
    Good policy.
  13. pasadena_commut
    pasadena_commut Senior Member
    2,549
    759
    Southern California
    A new OEM battery is ~$2000 if you install it yourself. The Prolong charger/recharger is ~$600 (last I heard). Does it make sense to spend 1/3 of the price of a new battery for this sort of bandaid? Balancing a battery using one of these devices may give it a year or two more, but a new battery is probably good for 15 years. The former only makes economic sense if you don't expect to keep the car for very long.
  14. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Installing the prolong harness and maintaining the battery starting in 2017 has allowed the battery in our old 2010 to continue operation:).
    So that's more than two years;).
    If done consistently following the directions, the battery life can be extended(y).
    markinuckfield likes this.
  15. alftoy
    1,132
    516
    You are talking about your vehicle. More than a few suckers have spent $700 or more to only end up buying a new HV battery.
    Consider that a Prolong uses Meanwell components.
    #15 alftoy, Nov 25, 2021
  16. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    We also used the Prolong equipment to rebuild batteries;).
    It has many uses for one purpose:).
    I got my investment back and then some(y).
  17. sam spade 2
    7,035
    2,801
    2017 Prius c
    Well......you don't KNOW that because you have no way of knowing what the life would have been had you done nothing.
    But you probably won't understand that either.
    alftoy likes this.
  18. R-P
    R-P Active Member
    804
    288
    Netherlands
    I read this as a derogatory comment, is it meant as such? Honest question. Among a Dutch electronics forum*, Meanwell is seen as an excellent brand, delivering a quality that is consistant at a pricepoint a little above the poorly designed China crap.
    It doesn't have the quality of e.g. my Delta Electronics PS that supplies me with spare components after 30 (!!!) years free of charge, but Meanwell is adviced to all without much reservation.
    PS: I don't use or have any Meanwell PS.
    * many on that forum have intimate knowledge or even design SMPS, so I trust their judgement.
    Raytheeagle likes this.
  19. alftoy
    1,132
    516
    Well you are wrong! The $100 Maintenance gear uses Meanwell power supplies, same as Prolong.
    Can I borrow your battery charger/balancer/reconditioner? | Page 7 | PriusChat
    Build Hybrid Battery Maintenance Gear For Under $100 | PriusChat
    HCH1 DIY IMA Reconditioning - Electric Vehicle Forums
    #19 alftoy, Dec 17, 2021
  20. alftoy
    1,132
    516
