Charging a Plug in Prime in the rain
Discussion in 'Prime Plug-in Charging' started by Prime_Rib, Apr 6, 2026.
  1. Prime_Rib
    Prime_Rib New Member
    Virginia
    2020 Prius Prime
    Razz me all you want folks. In the end, though, I need to know the answer. I have to plug in my car outside. It gets rained on. The entire cord is dry except where it plugs into the car. Are there short and long term consequences to this. If it matters, I've been doing this for 4 years and haven't had an issue, but that doesn't mean those consequences don't exist. TIA.
    52,558
    from experience, you can charge in the rain, sleet, snow, cold, heat, you name it. it's never been an issue, and I did it for 11 years
    Prime_Rib and BiomedO1 like this.
  3. BiomedO1
    BiomedO1 Senior Member
    4,374
    2,301
    Left Coast
    You just need to keep that safety cut-off brick dry and out of the water puddle. That will shut EVERYTHING down, if it senses an issue. Inspect the handle, pins and cable every once in an while. Repair or replace; when necessary.
    I've read that some company has made a rain/snow sock for the plug-in area; that shields it. Perhaps you can find it on an internet search. It's been 5 years on mine; but I'm partially covered by my houses' roof line.
    Prime_Rib likes this.
  4. Prime_Rib
    Virginia
    2020 Prius Prime
    Yes, that stays out of the rain. Thanks. I looked up and quickly found a cover. Doesn't sound like it's needed, but $20 for some assurance might be worth it. Much more expensive to replace the system.
    BiomedO1 likes this.
  5. Prime_Rib
    Virginia
    2020 Prius Prime
    Just what I needed to hear. Thanks.
  6. PHEVisthefuture
    PHEVisthefuture Junior Member
    49
    16
    Illinois
    You can charge in the rain; however, I'm always worried about corrosion getting into the connectors after the last person who used the EVSE left it on the ground, in the snow, instead of in the charging cradle (seen that a lot at public free chargers). I've charged many EVs in damp conditions and had zero issues.
    Please make sure your electrical circuit at home is either on a GFCI breaker or GFCI outlet if you plan to use a portable cord.
