Charging Area wet
Discussion in 'Prime Plug-in Charging' started by yoyoman, Dec 15, 2016.
  1. yoyoman
    yoyoman Active Member
    342
    117
    San Jose California
    I have parked my car in the rain today. After a day of raining, I opened my charging push door and found the entire charging area wet. Luckily the plug has stopped water getting into the contacts.
    Is this a concern? I will try to put weatherstrip foam from home depot to see if helps.
    iPhone ?
    49,842
    no worries, and no need to go beyond what toyota has provided. someone else posted about this as well. the pip has had an open charging area for almost 5 years with no problems, and charging outside in rain and snow is not an issue.
  3. fotomoto
    fotomoto Senior Member
    5,603
    3,781
    So. Texas
    Nope.
    J1772 considers this and other scenarios like standing in a pool of water in its charging standard for plug-ins.
    #3 fotomoto, Dec 15, 2016
    49,842
  5. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    With the snow that's been falling lately I have been using a 160 mph leaf blower to clear out the snow from the charge port area as well as the snow on the rest of the car
  6. yoyoman
    342
    117
    San Jose California
    iPhone ?
    priuscatprimeguy likes this.
  7. bisco
    49,842
  8. bisco
    49,842
    yup, no worries. plug her in!(y)
  9. yoyoman
    342
    117
    San Jose California
    Just want to clarify. I did not leave the door open in the rain. Look like someone spray water directly into the charging Area leaving it wet..:)
    iPhone ?
  10. bisco
    49,842
    yes, that is how they have been for 5 years. and now the prime is the same. the outer door is not waterproof.
    it's a non issue, but feel free to stick weatherstripping all over your new car if it makes you more comfortable.:)
  11. iplug
    iplug Senior Member
    2,456
    1,704
    Rocklin, CA
    @bisco, with all of these duplicate posts and your unofficial status as Priuschat-Citizen-in-Chief, you should be nominated to an official position as such with request that the gods (Danny and his demigod moderators) grant you privileges to clean up these posts.
  12. bisco
    49,842
    i relish the thought. but they know i'd be dangerous.:sneaky:
    plus, i'm technically incompetent. can't even upload an avatar.:(
    and, they can't afford me.:p
    iplug likes this.
  13. iplug
    iplug Senior Member
    2,456
    1,704
    Rocklin, CA
    You'd be fine, more likely to be level headed than most of us.
  14. john1701a
    john1701a Prius Guru
    12,761
    5,247
    57
    No concern. The design is well thought out. I've recharged in heavy rain a number of times. I've also had to brush off wet snow. No problem.
    Dudley1030 likes this.
  15. CaliforniaPrius
    CaliforniaPrius Active Member
    313
    201
    Alameda, California
    Do we need to drill weep holes at the door?
  16. Bluegrassman
    Bluegrassman Active Member
    229
    185
    US
    I'm no expert, but I would assume Toyota anticipated rain might occur during charging so I would think this isn't a problem. But I've been wrong before
  17. yoyoman
    342
    117
    San Jose California
    Sorry for the dup posts. For some reason I'm keep getting error message to wait for 30sec in order to post.. therefore making my question posted multiple times.
    iPhone ?
  18. MikeDee
    MikeDee Senior Member
    1,558
    593
    San Francisco Bay Area
    Is the Toyota charge cable GFCI protected or does it rely in your electric outlet being so?
  19. Lee Jay
    Lee Jay Senior Member
    5,850
    4,024
    Westminster, Colorado
    "Connect to an AC 120 V outlet (NEMA 5-15R) with a Ground-Fault Circuit-Interrupter (GFCI) and a circuit breaker."
    Owners manual, page 122.
  20. bisco
    49,842
    drilling holes in your brand new car sounds like a fine idea.
    #20 bisco, Dec 16, 2016
    Mendel Leisk and Neohippy like this.
