Charging at the office ...
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Electric Charge, Sep 28, 2012.
  1. Electric Charge
    Electric Charge Active Member
    545
    133
    Syracuse, NY
    Has anyone managed to convince (or at least tried to) their employer to install a charging station (and maybe even help pay for it on a monthly basis, using the savings from not having to use gasoline)?
    I'm 20 miles away from home, so I'm trying to come up with a good plan and maybe talk to my employer/building manager about it (probably a long shot).
  2. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    does he have a 120 volt outlet available? also since you're 20 miles away, if you can allot the time and have access to side roads with a speed limit of 25mph you could stretch your EV to 15 miles. I've done that going about 15 to 17 mph on the side streets on my way to work.
    51,141
    if you charge 10 miles per day at work, x 5 days a week, that's a bout a gallon a week at 50mpg. offer them $4./week = $200./year for 5 years = $1000. should cover about half the cost or more.
  4. Electric Charge
    545
    133
    Syracuse, NY
    I already take the back roads to work (with several stretches of 30mph), probably as good it is going to get.
    There currently is no outlet available (or rather, I haven't found any), but even if there was, the problem is the sidewalk and distance. It's a business park with 3 large buildings and large parking lots (with several businesses in each building), so I need to find a spot which wouldn't create a tripping hazard.
    As for the math, that's close to what I was thinking. I wouldn't pay for the entire thing, since others could use it as well, but maybe use it as an incentive. I'll have to get a hold of the building manager and see what he says. I was hoping others have tried this as well.
  5. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
  6. John H
    John H Senior Member
    2,208
    558
    for a PiP, just a 110V outlet would go a long way at 1.4KW.
    The L2 charging stations are very attractive for the PEV and PHEV with larger batteries and chargers, so don't be surprised if you find yourself bumped from an L2 station plug.
    Most L2 chargers are setup to provide 7.2KW and I think your PiP can only sip about 2KW.
  7. Electric Charge
    545
    133
    Syracuse, NY
    Yep, I would settle for a regular outlet, since the car sits here for at least 8 hours each day. But still need some sort of infrastructure.
    As far as I can tell, all charging stations in my area are either dealer owned, or ChargePoint units ($2.40/hour), but there is nothing closeby anyways, defeating the purpose of my idea.
  8. John H
    2,208
    558
    Have you looked around for an existing 110V outlet? check the parking lot light poles and areas around the AC equipment or landscape maintenance storage sheds. If you can find an existing outlet the next step is pretty easy and often just involves asking permission since charging a PiP from empty is equivalent to a cup of cheap coffee.
  9. Electric Charge
    545
    133
    Syracuse, NY
    Hmm, didn't think of checking the parking lot light poles. Would be really cool (and maybe make it also easy to install a few outlets). Thanks for the idea!
  10. inventor00
    inventor00 Active Member
    1,131
    60
    Phoenix, AZ
    We looked all around the parking garage, no outlets, but since there are 4 of us, we convinced them to put in a 220 charger... we may eventually need another one..we also lock it with a combo lock so others (no employees) cannot use it and all 4 of us know the combination.
  11. MJFrog
    MJFrog Active Member
    780
    267
    NE Oklahoma
    2018 Nissan LEAF
    I've got an '04 with a 4kwh PHEV conversion. My company owns the parking structure here and has installed at least 4 chargers I know of (the Volt guys use them mainly). However, I only need a 110v outlet and permission to plug-in...which I finally got in April 2011, after almost 2 years using a 2kwh pack.
    I can refill my pack in 2.5 to 3 hrs with the 3.2-3.5 kwhs I use up on the morning commute. No cost to me, but I can't speak for the guys using the chargers...last I heard they were NOT being charged. Access to charging at work is roughly equivalent to a $7.50/month subsidy on my commuting expenses. I'd gladly pay that if they wanted it...probably cost them more in bookkeeping than electricity used though.
  12. Sometimes there are outlets behind buildings.
  13. Paradox
    29,110
    8,591
    201
    2014 Prius v wagon
    Most of those parking lot lights run at (I think) 230v so more often than not you don't see 110v outlets on them.
  14. John H
    2,208
    558
    240V split phase is fairly typical, but that is 2 x 120V circuits on different phases to get 240V, very easy to get a 120V outlet, or a 240V outlet from them.
    Some garages are 208V out of a three phase service which is different than single phase/split phase. There are some folks that have configured a transformer to get the 208V up enough to do a L2 charger at 240V but it isn't very portable. works well if you have an assigned spot in a garage, like a condo.
  15. Paradox
    29,110
    8,591
    201
    2014 Prius v wagon
    The lamp posts where I work are something in the 200 range, 208, 230 i do not know, what I do know is someone who is an electrician there told me it isn't as simple as just adding an outlet to the pole since it requires more equipment like a transformer or something to do it. He said it is still doable but not as cheap. That was the point I was trying to get across.
    John Hatchett likes this.
  16. 9G-man
    9G-man Senior Member
    1,273
    194
    Atlanta, GA
    Better ask first. I found a light pole at work with a 120v outlet and used it several times without asking. Someone noticed and I got an email asking me to stop pluging in....
  17. That is one way of bringing the problem to people's attention. I have only had one very large worldwide company refuse me, I plugged in and asked. They said they would get back to me, never did. I put it down to major ignorance.
