Charging battery from points under hood??
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by America808, Apr 21, 2021.
  1. America808
    America808 New Member
    Honolulu, Hawaii
    2016 Prius c
    Can you charge the 12v battery from the same points that are used for jumping with a maintainer that has to be plugged into electrical outlet (under the hood) or does it have to be charged from the points on the battery under the seat? I have a 2016 prius c le.
    49,500
    yes, you can charge at the jump point, it is a direct connection to the battery.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    Not only is it OK, it is recommended.
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    Read your manual.
    Hence the name jump point. Just be careful with polarity a Prius is the last car you will want to do reverse polarity jump.
    if your a novice jumper buy a jump pack that has reverse polarity protection it won’t turn on if it detects it’s hooked up wrong. There handy and not expensive and could save you hundreds of dollars if you goof up.
    If you garage the car buy a charger/maintainer and leave it on the battery via the front jump point when not using it that way battery stays 100% charged at all times.
    Consistently killing the battery will destroy it.
    during covid we see many dead cars as they don’t drive much. Try to take your car for a ride every few days nice 10-15 mile highway drive it will keep both batteries charged. That’s what my wife does with her g2.
    good luck.
    ralph seifer likes this.
  5. Mendel Leisk
    38,728
    Do it ALL the time. Got tired of alligator clips and wired in a quick connect (that came with my CTEK charger).
    fuzzy1 and edthefox5 like this.
  6. edthefox5
    10,096
    4,806
    Clearwater, Florida
    I like my Citek. I bought because you recommended it actually.
  7. Mendel Leisk
    38,728
    Prices have really gone up though. :confused:
    edthefox5 likes this.
  8. fuzzy1
    10,170
    Putting in those quick connects for battery tenders (other brands but same connectors) in all the cars was the first thing I did a year ago, after getting home from our road trip that was prematurely aborted by the pandemic lockdowns.
