Charging Cable Durability
Discussion in 'Prime Plug-in Charging' started by Ray Moore, Jul 7, 2018.
  1. Ray Moore
    Ray Moore Active Member
    857
    52
    Texas Hill Country
    How durable is the charging cable? If I leave it outside in Texas and it sees sun for 4 hours a day will it last one year, five years or ten years. I see these charging stations holding up pretty well. How does our cable compare. It would be nice if I could just leave it coiled on the outside wall.
  2. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    If you posted in the older Gen 1 plug in forum, you might find someone with 5 years experience, no one here is likely to have 2 years experience. I have no idea where you could get a review from some one with 10 years experience.
  3. jerrymildred
    jerrymildred Senior Member
    11,511
    14,113
    Tampa, FL
    I have never heard of a weather or UV related failure on a PiP EVSE cable. Mine is in partial sun all day for 4 days a week at work. That's been for over 18 months. No idea how the previous owner used it. It's still very supple and has no cracks.
    Glenn G and Ray Moore like this.
  4. bwilson4web
    15,523
    The biggest risk is falling against the J1772 which breaks the 'tooth' on the locking latch. I've seen two at Whole Foods and I was clumsy one night juggling groceries and dogs and broke mine which I've repaired.
    jerrymildred likes this.
  5. CraigM
    CraigM Active Member
    208
    208
    Portland, Oregon
    I’ve had an EV / PHEV for four years (Fiat 500e prior to the Prime). Although I don’t store my EVSE outdoors, I did have one EVSE damaged in my garage three years ago by MICE! It seems mice think the cable is tasty. Needless to say, I now keep the cable off the ground when not in use.
  6. benagi
    benagi Active Member
    525
    280
    Utah
    Question about the stock 120v evse that comes with the Prime. Should I unplug it from the outlet every time the car has completed its charge or is it OK just to leave it plugged in the outlet? Just curious if it is hard on the outlet to continuously plug and unplug ever day.
  7. jerrymildred
    11,511
    14,113
    Tampa, FL
    There is a small amount of energy consumed by the EVSE when it's idle. Probably much less than your TV when it's turned off.
    There is also a very small amount of wear and tear on the receptacle when plugging in and unplugging.
    There is also the small chance of a stray voltage spike from lightning or some other source damaging the EVSE when plugged in.
    I don't think any of those are significant enough to fret about. As for me, I unplug mine when not in use. The worst that could happen is that I'll have to replace a loose receptacle in about 20 years. If I'm still alive at 85. ;)
    Glenn G and benagi like this.
