Charging Cable Extension
Discussion in 'Prime Plug-in Charging' started by Chris Martin, Aug 20, 2019.
  1. Chris Martin
    Chris Martin New Member
    Houston, Texas
    2019 Prius Prime
    Good afternoon all.
    This may have been discussed before, but my plugs are not in the most convenient location in relation to my driveway. When charging, I have to shuffle the cars around in the driveway and put the Prius in first. In morning, I have to move all of the cars again to get the Prius out. Inconvenient in the morning.
    What has been your experience with an extension? I have seen some on Amazon, but I'm not sure of the issues, current loss, etc. Here's one:
    Is this an option? I could use twenty extra feet and not have to move all of the cars just to charge. Any advice would be greatly appreciated.
  2. Salamander_King
    Salamander_King Senior Member
    10,975
    8,867
    New England
    You don't need expensive 40 Amp, 20ft, J1772 Extension Cable. All you need is heavy duty regular 120v extension cord of 12AWG or 10AWG. If the brick part of the EVSE is going to be outside, you might want to invest in weatherproof box to place the connection part. Something similar to the photo below.
    Rob43 likes this.
  3. fuzzy1
    10,170
    And get the shortest cord that works, e.g. just 25 feet instead of 50 or 100. The shorter the cord of a given gauge, the less the voltage drop.
    Rob43 likes this.
  4. Rob43
    Rob43 Senior Member
    1,373
    1,047
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    Yep, I agree with what's been said above.
    Personally I like 10 AWG, it will have very little (almost none) loss at 25 ft.
    Another thing you may or may not know is that you can use your 120v OE Toyota EVSE unit at 240 volts to charge your car in less than half the time, typical full charge time is 2 1/2 hours on 240 volts. If you have any questions, let me know.
    Rob43
  5. bisco
    49,492
    its the plugs that get hot. get a good quality
    Rob43 likes this.
  6. hill
    8,185
    that's right .... & THAT'S why the most expensive way is the best way. It's called future-proofing. Someday you may need to charge somewhere above a paltry 3.6 kw's;
    JLONG - 20 foot J1772 extension cable
    When that day comes, & you are charging on 240V - 30amps, & you still have a long run, you'll be glad you went this route.
    But if you think you'll be stuck on 120v forever? Then sure, go for a extension cord.
    #6 hill, Aug 20, 2019
    TGrracie and Chris Martin like this.
  7. Chris Martin
    Houston, Texas
    2019 Prius Prime
    That's great. Do you just put a 240v adapter on?Unfortunately, I only have a 240v in my washroom. I'm really not concerned with charging speed because I charge overnight.
    What I wish was I had 2 or 3 times the battery capacity! Then I'd never use the ICE again.
  8. Rob43
    Rob43 Senior Member
    1,373
    1,047
    2013 Prius v wagon
    Yep, bigger capacity would be great !
    Yes, you just put an adapter on your EVSE unit.
    I make these adapters all the time for people using the best materials:
    Using the Primes 120v Charger at 240 Volts, Cost $20 !!! | Page 6 | PriusChat
    Rob43
    Chris Martin likes this.
  9. hill
    8,185
    240 is around 10% more efficient than 120v.
  10. fuzzy1
    10,170
    While future-proofing may be a good idea, it may not work out as cost effective if done prematurely. Prices fall with volume, standards change, sometimes the future goes a different path. So $200 for this cord, vs $25-30 for a 120V 12AWG extension (or $35-40 for a 10AWG extension), I'd go with the common 120V extension for now. Wait until a future car with bigger battery comes along before getting that J1772 extension, along with a 240V outlet in the garage.
    Also:
    If something seems to be getting hot, or the EVSE and car get finicky with an extension cord, you might be running into the reasons Toyota discourages extensions in the first place. If so, you can buy some margin by reducing the charging rate from the original default 12 Amps (on 120V, more on 240V) to just 8 amps. (For how to, see owner's manual.) This will cut the parasitic cord and plug heating in half, and cut the voltage loss (in the house branch wiring too, not just in the extension cord) by 1/3rd. If you are charging over night, the longer charge time will not be an issue.
  11. john1701a
    john1701a Prius Guru
    12,755
    5,245
    57
    Of course, that could result in missed opportunity. Electric providers may not be offering rebates then. We got $500 for each line setup. No harm checking what's available now.
    hill likes this.
  12. Chris Martin
    Houston, Texas
    2019 Prius Prime
    Last night I purchased a 25' extension, and everything went smoothly. No real heat at the plug in the wall, the connection to the charger nor the line transformer. Had a full charge.
    I presume no issues.
    Salamander_King likes this.
  13. hill
    8,185
    it looks like the OP was hoping to charge 240V, ergo, the 240V solution. Equally important, if you're out and about, needing a charge, it's all too common that some moron will ice public charging spots. A 240v J1772 extension, will let you work around such shenanigans. That's especially important for an EV, as opposed to a phev.
    Pricey? For some, sure. Extended car warranties are expensive too. Homeowners insurance is pricey too. It's crucial though, in times of Dire Straits. Everybody has to assess their own risk vs benefit.
  14. Chris Martin
    Houston, Texas
    2019 Prius Prime
    I want to rant today about charging stations.
    This morning, two ICE SUVs in EV Class2 spaces and a Tesla owner pulls in and doesn't plug in. I guess Tesla charging spaces double as lazy Tesla owner spaces.
    noonm and Rob43 like this.
  15. noonm
    noonm Senior Member
    575
    595
    2018 Prius Prime
    Call the lot owner and ask them to ticket/tow the non-EVs.
    For the Tesla, I'd put one of these notes on the windshield:
    Prius from Dad and Rob43 like this.
  16. hill
    8,185
    Just as people park cars in the wrong spot ...... PC members park their rants about such things in the wrong spot
    Plug-In Parking Abuse Hall of Shame: Post Pic's Here | PriusChat
    Raytheeagle likes this.
  17. Gaëtan Lafrance
    101
    77
    Montréal, Québec
    Technology
    Bonjour,
    I use 15 metres extension 10AWG and it's ok.
  18. Chris Martin
    Houston, Texas
    2019 Prius Prime
    Sufficiently reprimanded
    jb in NE likes this.
  19. mveras1972
    mveras1972 Member
    173
    63
    New Philachussetts
    Until recently I was using two 15A orange extension cords and they got warm around the plugs during charging. They are both 14AWG. One of the extensions got cut in the past when I was trimming some bushes one day and I patched together as seen in the picture. I soldered the wires together to repair it. I monitored this particular spot and never noticed any warming when charging the Prius. The point is, it all depends how good the connection is. Good connections will prevent warming.
    #19 mveras1972, Sep 1, 2019
  20. bisco
    49,492
    absolutely. that's why a lot of people recommend the screw terminals on a wall outlet, instead of the push in connections.
    well done! (y)
