Charging Cable Kinks
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Jeffrey Perlman, Jun 20, 2013.
  1. Jeffrey Perlman
    Jeffrey Perlman Junior Member
    2013 Prius Plug-in
    How do I straighten out a charging cable that kinks? How do I prevent it from kinking again?
  2. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :confused:Which charging cable are you referring to? The factory EVSE that came with your plug in? Mine is very flexible, might tangle, but not kink. My Leviton Level 2 cable (10 gauge wire) is so thick, I doubt I could tie it in a knot.
    51,140
    i think you just have to be more careful. what situation is it kinking in? are you in a cold climate? lay it in the hot sun for the day and try to unkink it by bending the kink in the opposite direction. when coiling and un coiling, make sure you're twisting the cable everytime you make a loop, or untwisting it when uncoiling. there is a thread here with video showing how to properly coil an electrical cable.
  4. Norman Jensen
    Norman Jensen Junior Member
    I have the same problem. I am trying the lay it out in the sun solution. I have layed it out before and untwisted it only to have the problem return. I don't think I am twisting every time plug or unplug it. I am in CA and car is in the garage. Cold temperature is not the problem.
  5. bisco
    51,140
    it won't kink if you rotate the cable as you loop it onto the hanger, and unrotate it as you take it off. (y) as for unkinking, i can't think of anything except bending the kinks the other way.
