Charging cable life?
Discussion in 'Prime Plug-in Charging' started by Tickwood, Oct 7, 2019.
  1. Tickwood
    Tickwood Active Member
    334
    101
    San Diego
    2020 Prius Prime
    page 118 of the Owners manual says that if the Charging cable lifespan notice is flashing "...The number of charges using the charging cable is nearing the end of its usable life span. Consult your Toyota dealer"
    Does anyone have any idea if how many charges make up its usable life span. has anyone ever worn out a cable?
  2. Tideland Prius
    16,671
    Tips, TGrracie, MTN and 2 others like this.
  3. Tickwood
    334
    101
    San Diego
    2020 Prius Prime
    52,784
    i think pip was only 20k. don recall anyone reaching it after 8 years
  5. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    What is it that dies? the jacket, the plugin. what is the cause? old age.
  6. bisco
    52,784
    tide says firmware. i guess it loses its grip
  7. vvillovv
    vvillovv Senior Member
    4,336
    1,518
    NY
    My OEM cable has always fit easily into the charge port of the car. I notice on newer EVSE installations that the cable end fits much more snuggly and is someimes hard to remove from the charge port.
    After 30,000 in/outs I'd imagine both the plug and the socket might be kinda wobbly worn.
    By than there will surely be a firmware hack to extend the OEM's lifespan so we wouldn't have to pay the $2000 replacement part in the year 2099
  8. m8547
    m8547 Senior Member
    951
    631
    Colorado
    2018 Prius Prime
    Probably relay contacts, but by that time all the other parts of it will probably show a lot of wear as well.
    CraigM likes this.
  9. Salamander_King
    Salamander_King Senior Member
    11,024
    8,977
    New England
    In 82 years, I will be dead for sure. LOL :ROFLMAO:
  10. Tino
    Tino Junior Member
    Lowell, MA
    Has anyone had the plug stop working? I have a prime 2017 actually bought in March 2018 and last night when I plugged it in I didn’t hear the usual click when you plug and it didn’t charge overnight. It charges normally on the ChargePoint stations. I did notice that comes off if you pull it even if you don’t press the button which is probably the cause of the problem. It seemed like a pretty robust plug was not expecting this....
  11. Rob43
    Rob43 Senior Member
    1,373
    1,050
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    Nope.
    Trouble shoot it in the daylight, then try it again.
    Rob43
  12. bisco
    52,784
    sounds right. can you look inside to see if the mechanics are okay. maybe something foreign lodged in there?
  13. vvillovv
    4,336
    1,518
    NY
    That click is important. Next time you don't hear that click when you push the charge cable into the charge port, pull it out and try inserting it again.
    jerrymildred likes this.
  14. Tino
    Tino Junior Member
    Lowell, MA
    Looked at it in daylight and saw nothing out of the ordinary nothing bent or lose
    Tried that numerous times it seems loser than the L2 ChargePoint plug
    Realize the click is important but it doesn’t happen. It also doesn’t lock and seems loser than before. Should I try to open it to see if there’s anything broken or out of place?
    #14 Tino, Nov 6, 2019
  15. vvillovv
    4,336
    1,518
    NY
    What about other charger cables? Like a checkpoint charge station.
    Do you get the click?
    I wouldn't tamper with the OEM cable, Not yet anyway!
    See what others say.
  16. Tino
    Tino Junior Member
    Lowell, MA
    I don't hear the click on ChargePoint station but it locks for sure. Running out of options here... it seems there is something definitely wrong with the plug.
  17. Tino
    Tino Junior Member
    Lowell, MA
    Here’s what the plug looks like currently. I don’t see anything out of the ordinary except for Normal wear and tear.
  18. bisco
    52,784
    does it go in all the way? and if so, what is the locking tab doing? even without the click, it can close properly, which would allow charging.
    also, is the light on the brick on?
  19. Tino
    Tino Junior Member
    Lowell, MA
    the light on the brick is on and it goes in all the way as far as I can push it in (don't wanna force anything). The locking tab doesn't seem to go down more either. I will try to open the plug at this point to see if there's any broken component.
  20. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    If the locking tab isn't going down, either the plug isn't all the way in because something is blocking it or else something is preventing the tab from dropping into place behind the retainer in the charging port. Since charge point works, the problem would most likely be in the plug on your EVSE rather than on the port on the car.
    Your picture in post 17 is nice and clear, but at that angle, we can't see if maybe there is something stuck on the back side of that locking tab and holding it up so it won't snap down into place.
