Charging Cable Plug
Discussion in 'Prime Plug-in Charging' started by ukr2, Jan 28, 2017.
  1. ukr2
    ukr2 Senior Member
    1,009
    275
    31
    Victor, NY
    Toyota wasn't listening !!!
    Just like my 2012 PIP, the Prime charging cable comes with a Straight 120 volt Plug.
    It doesn't fit under my outdoor weather cover.
    So as I did in 2012, I'm ready to cut off the Straight plug and add a Right-Angle plug. This will reduce the strain on the plug since the cable and weight of the Brick is straight down.
    Home Depot has the plug, Legrand Straight Clade Angle Plug for $11.49. Online others are cheaper.
    Has anyone come up with a better idea ???
  2. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    I would add a thin rope or string from the brick to hang over your right-angle plug to take tension out of the cable.
    Andyprius1 likes this.
  3. ForestBeekeeper
    ForestBeekeeper Active Member
    706
    276
    Maine
    Tension in the cable means that you park too far away from the outlet.
    Can you adjust the parking space, to be closer?
    Or can you move the outlet?
  4. dalcon95
    dalcon95 Senior Member
    512
    653
    Easley, South Carolina
    I think the tension that is talked about is the gravity pull on the cable from the plug. There is some weight pulling down from the weight of the cable. I saw there are holes on the box down stream from the plug to mount it on the wall to keep the weight of the cable from pulling on the plug.
  5. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    yup, with this extension my brick lies flat on the ground.:D Plus you don't void the warranty on the EVSE by mutilating the cord to put a new plug on it:whistle:
    #5 priuscatprimeguy, Jan 28, 2017
    Arctic_White likes this.
  6. bisco
    49,490
    too bad they don't make a right angle adapter.
    priuscatprimeguy likes this.
  7. ukr2
    ukr2 Senior Member
    1,009
    275
    31
    Victor, NY
    The weight of the Brick on a Straight plug wants to pull the plug out of the outlet.
    With the Right-Angle Plug, there is NO problem and you don't need any other hooks or cords.
    And it keeps the Brick off the ground, snow or puddle.
    I gave my modified cable to the person that buys my 2012 PIP.
    Changing the Plug should NOT void any warrenty. It had a BAD Plug !!!
  8. priuscatprimeguy
    2,730
    2,640
    yup, the key word is "SHOULD":D
  9. Db17
    Db17 Member
    188
    92
    Visalia, CA
    How about just adding an adapter. Something like this (although 12awg would be better)
  10. ukr2
    ukr2 Senior Member
    1,009
    275
    31
    Victor, NY
    OK. Cable now has the Right-Angle Plug. And don't call the Cops. I removed the cable warning tags !!!
    Here's the Straight Plug, unable to close the weather cover, and the weight of the Brick pulling the plug out of the outlet -
    The Right-Angle Plug with the weight of the Brick not affecting the outlet. No hangers needed. -
    And with the Door Closed at Home -
    And my setup at Work -
  11. ukr2
    ukr2 Senior Member
    1,009
    275
    31
    Victor, NY
    OK, WAIT. Don't change your Plug yet.
    I'm getting a "Plug temperature detection malfunction".
    There were 2 extra wires in the cable that might be going to a thermister as a Temp Sensor.
    The old Prius didn't have this.
    I left them unattached and will have to verify.
    Does anyone have any Facts? No Guesses please.
  12. IMkenNY
    IMkenNY Im just being nosy
    477
    303
    Tropical Buffalo NY
    Four Touring
    oops, break out the soldering iron, sounds like a missing thermistor. (measure the resistance on those extra wires going to the plug to verify)
    That's a nice upgrade considering the plug/outlet connection has the potential to be a weak point with an aging outlet.
  13. ukr2
    ukr2 Senior Member
    1,009
    275
    31
    Victor, NY
    right
  14. ukr2
    ukr2 Senior Member
    1,009
    275
    31
    Victor, NY
    I went to my Dealer's Parts Dept.
    The Charging Cable, #G9060-47130, costs $843.43. WOW.
    The Straight Power Plug tail-piece, that disconnects from the Brick, #G90G0-47120, costs $147.42.
    They DON'T list a Right-Angle tail-piece.
    He suggested I call Leviton.
    I asked him to call Panasonic who makes it for Toyota, since their phone number he gave me only speaks to Dealers.
    So since I already cut the Straight Plug off and attached the $11 Right-Angle plug from Home Depot, I bought a 25 cent 270 ohm resistor from Radio Shack, soldered it to the 2 extra wires in the plug, usually for a thermistor that measured 274 ohms at 70 DegF in the house, screwed the plug back together and it works. GREAT !!! Ready for another 5 years of charging.
    Mendel Leisk, bisco and Since2002 like this.
  15. priuscatprimeguy
    2,730
    2,640
    MURDERER!!!!!!!!!:p
  16. Optimus PRIME
    Optimus PRIME Active Member
    180
    141
    SF Bay Area
    Wow, nice work Ken. Did you add the outlet on the window for your office as well?
  17. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Compared to $843.43 this looks affordable: amazon.com/Electric-Vehicle-Charger-Portable-Charging/dp/B01ERTBKY4
  18. ukr2
    ukr2 Senior Member
    1,009
    275
    31
    Victor, NY
    Yes, it's Plexiglass with weather stripping.
    Back of outlet wired to extension cord to office outlet with P3 Kill A Watt meter.
    I record the kwh everyday to a calender. I do the same at home. Every fillup I total them up.
  19. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    So, by cutting out the molded stock plug it seems you have lost the new safety feature built into it, of protecting the wall socket / plug from over temperature due to a bad connection. This is a very important safety measure for portable EVSE ! Can prevent fire in extreme cases.
  20. jerrymildred
    jerrymildred Senior Member
    11,511
    14,113
    Tampa, FL
    I've been eying that for a while. Problem is, I don't really NEED it. It sure would be convenient, though. And they will install it for only $315 more. Maybe they mean they will install an outlet.
