Charging cord repair?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by RobertF, Feb 17, 2017.
  1. RobertF
    RobertF New Member
    Gig Harbor, WA
    Does anyone know of any companies that repair the charging cable itself?
    I plugged mine in, and it does not light up at all. I am familiar with electronics, so yes, have tried resetting it, and have tried different outlets. It is the electronics box itself. Somehow a power spike bypassed the safety equipment.
    52,386
    welcome! have you tried toyota? there is a company that changes them for 120 to 120/240, maybe they can help.
    RobertF likes this.
  3. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    If I found my EVSE started having trouble, I'd send it to EVSEUpgrade. I would hope whatever failed would be taken out for the upgrade to level 2 anyway.
    I doubt the dealer would do anything for me besides provide a replacement and charge me accordingly if not under warranty.
    Here's a good video on a repair on a Volt EVSE.
  4. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    If you wind up replacing it, I'd like to buy the broken charging cable. I need some parts from one.
  5. RobertF
    RobertF New Member
    Gig Harbor, WA
    Do you know what this company is? I called my local parts department, and they were of little/no help.
    Thanks
  6. bisco
    52,386
    evseupgrade.com, as in post #3 by modem above.
  7. randy plugin
    randy plugin Junior Member
    Minneapolis, MN
    I have a broken 2012 Prius plugin factory evse charger. I got a new one and the old one is sitting in my garage. What would you offer for the old factory evse?
  8. Rebound
    3,996
    2,645
    Portland, OR
    Oh, I can't offer you enough for a working one. I just need the little metal piece that latches it to the car; I'll only pay $20, which is not fair for a working one. Mine works even though it doesn't latch, so it's not worth hundreds of dollars to me.
  9. Jenny Seiber
    Jenny Seiber New Member
    Niota, IL
    Hello! Is anyone looking to sell a working charger for a 2012 prius plug in? Mine isn't working and i'm looking to purchase one. Please respond if you have anything available. Thanks!
  10. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
  11. RobertF
    RobertF New Member
    Gig Harbor, WA
    Look up the EVSE website... They sell them also.
    bisco and priuscatprimeguy like this.
  12. Redpoint5
    Redpoint5 Senior Member
    1,026
    509
    Portland, OR
    Hah, Toyota. Those monkeys will gladly "fix" the problem by selling another $750 EVSE. They aren't trained in cable repair; they simply replace things as assembled units.
    Assuming a break in one of the wires, it would be easy to locate using a continuity probe. The cables themselves are easy to replace; simply buy the same number of strands in the same gauge as the original.
    EVSE Upgrade charges too much for what they actually do, but that might be the best bet if you don't have the time / equipment to do the repair yourself.
    I upgraded a Leaf EVSE to level 2 (240v) for $25 and an hour of work. It's all I charge with now.
    jerrymildred and Yea Right like this.
  13. Yea Right
    Yea Right Active Member
    232
    115
    Seattle
    2014 Prius Plug-in
    You should do a DIY video on a cord conversion
    jerrymildred likes this.
  14. Redpoint5
    1,026
    509
    Portland, OR
    If I get my hands on another Leaf EVSE, I'll do that. In the meantime, the directions are pretty good on Instructables.
    With the number of companies supplying EVSEs, I'm surprised the price hasn't dropped by now. They are just extension cords with extra safety built in. The circuitry is super cheap, with the majority of the cost being in the copper wires.
  15. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    Looks like it should work. I wasn't sure what was in that black box. I'm not sure I'm quite comfortable with opening up my Toyota EVSE. I'm sure it works the same, but I think it's more of an emotional thing where I don't want to deface the factory original. I'll probably do it anyway once I find some spare time. Thanks for the link.
  16. Yea Right
    232
    115
    Seattle
    2014 Prius Plug-in
    The "Instructables" link shows converting a 120V to a 220V, at the same 12A rate.
    What advantages is the 220V (Level 2) at the same 12A?
    I always thought the benefit of the 220V, was to also have it at 30A for a quicker charge?
  17. jerrymildred
    11,517
    14,157
    Tampa, FL
    If you keep the current the same (amps) and double the voltage, you double the power (Volts X Amps). So you charge twice as fast with the same amperage. Actually, a little faster because you have the same heat loss and other overhead but for half as long. So L2 is a tiny bit more efficient, but not enough to pay for itself financially. It's more of a convenience.
    220 V at 30 amps would charge four times faster.
    Yea Right and Tracksyde like this.
  18. Rebound
    3,996
    2,645
    Portland, OR
    In a Prius Plug-in, the advantage to 220V is that charge time is cut in half, to about 90 minutes. The car will only draw 12A.
    You can make EVSE's with 220V at 15A, 30A, and more, but a Prius won't draw more than 12A. There are EV's which will. My cousin has a Leaf, and she's perfectly happy with the 110V EVSE that came with the car. I explained how I could run a new outlet, and she just didn't care at all. Plugs in at night and it's ready in the morning.
    Yea Right likes this.
  19. Yea Right
    232
    115
    Seattle
    2014 Prius Plug-in
    Cool, thanks
  20. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    I think you did a good job. I also had to do this on my 2012 Plug-in and just used splices and heat shrunk them. Not as neat as yours, but workable. Tinning the wires was a good idea tho.
