Charging failure
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by jfschultz, Sep 23, 2016.
  1. jfschultz
    jfschultz Active Member
    639
    115
    Germantown, TN
    2020 Prius Prime
    My Pip stopped charging! I would plug in and after a few seconds the charging light would flash ten times and stop. When starting the display would indicate a cable or other problem. I tried a public station and the same thing.
    I told the Service Advisor that this would give their techs a early preview of the Prius Prime. The dealer clocked 4-5 hours of diagnostic time and Cincinnati District even sent an technician to help. The verdict is that the charging ECU needs to be replaced. (Also a good charging ECU is needed to see whether the charger is OK or not.)
    The Service Advisor had called several contacts in California, including Carson Toyota, and this is the first charging ECU failure they heard of.
    Has anyone here encountered a similar issue?
    52,464
    i don't recall ever reading about one. we have had some chargers replaced though. it will be interesting to see if that fixes it. how many miles on her?
  3. Pluggo
    Pluggo Senior Member
    608
    534
    Folsom, Pennsylvania
    Just wondering, does the car still charge while coasting and braking? Hopefully you always used a grounded outlet, no questionable extension cords and you always connect and disconnect at the charging port while the charger is plugged into the wall. A body shop guy told me he was warned not to strike an arc on his welder anywhere near a Prius because of all the sensitive electronics.
  4. jfschultz
    639
    115
    Germantown, TN
    2020 Prius Prime
    I have a bit over 31k miles on the car.
    The only thing that was unusual, is that after plugging in and going inside, I found a circuit was out. I flipped several circuit breakers off and on to find the one that was tripped. So that may have cycled the socket it was plugged into. Also the GFI in the charger was tripped.
  5. Pasaman
    Pasaman Active Member
    289
    115
    Southern California
    Any trouble charging at public places? I can't charge reliably at home. It will charge 20 minutes or so and trip the gfi. At work I have no problems. I'm thinking it's my charger which looks beat to heck.
  6. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Too late now but I would have suggested rebooting/resetting all the car's ECM's by disconnecting the 12v.
  7. Mendel Leisk
    41,983
    This is covered under warranty I guess? Could you ask them what it cost if it was out-of-warranty? Be good to know.
  8. jfschultz
    639
    115
    Germantown, TN
    2020 Prius Prime
    Apparently, at least in the US, this is only covered beyond the basic in California and perhaps the other CARB states. The repair bill will come to about $1,100 for the charger ECU.
  9. fotomoto
    5,639
    3,815
    So. Texas
    Ouch. That erases much of your fuel savings.
    If this was somehow caused, at least partially, by the home circuity/resets issues, I'm glad I use a new, separate 240v circuit for my charging as my previous 120v garage socket has had numerous trips due to an air compressor being on the same leg (since moved).
  10. bisco
    52,464
    i would not be a happy camper if i had to pay for a defect like that on a 3 y.o. car.
    otoh, i wonder if the continual issues you are having with your outlet can eventually fry things, and why the require a dedicated circuit?
