charging mi 3g wifi router
Discussion in 'Gen 3 Prius Main Forum' started by ruidasilva, Sep 13, 2010.
  1. ruidasilva
    ruidasilva New Member
    ibiza
    hi there,
    i haave been using a huawei e5830 incar as a wifi hotspot...
    my problem is that it does not seem to charge when i connect it to the lighter... anyone has similar experience?
  2. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    There is no power on the lighter socket unless the car is in "accessory" or "ready".
  3. ruidasilva
    ibiza
    it seems to have not enough current for the modem.... as it does look like there is power going in but does not charge the modem... yes the car is on...
  4. avian
    avian New Member
    33
    Houston, TX
    It uses a standard USB port right? Then it takes 5v, up to 1amp probably... the cigarette lighter is giving out 12v @ 10 amps so check your charger and make sure it has the right amperage output. Have you tried plugging it into the usb port (assuming your prius has one)?
