Charging outside with weather conditions
Discussion in 'Prime Plug-in Charging' started by Hayden, Oct 6, 2018.
  1. Hayden
    Hayden Junior Member
    46
    2018 Prius Prime
    Forgive me if someone posted this already, but I couldn't find a thread.
    Because I live in an apartment the use of an extension cord will be imminent soon, especially in the winter when everyone is crammed in the driveway .
    My question is should I be worried about the power brick for the charger? I have an extension cord with a connection protector for the weather, but I feel odd about leaving the power brick in the snow when I'm charging from the front of my house via extension cord.
    What have you guys done in the winter/rain?
  2. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Toyota recommends against an extension cord. If it is too late to get a normal Prius, use a heavy gauge wire 10/3 as an example.
    www.amazon.com/dp/B000HEC2DW
    Toyota also recommends a GFCI outlet, for example www.amazon.com/dp/B071WD4Z4T
    Both are speced for 20 Amps, so your breaker should be too. Your actual charger will draw over 12 Amps for almost 6 hours, so the equipment has plenty of time to get hot with smaller wire.
    The car end has many weather fail safes, the dangerous end is the normal plug. www.amazon.com/dp/B009RX5GI2
    The large size may hold the bulge as well, but it won't provide ventilation.
    #2 JimboPalmer, Oct 6, 2018
  3. Salamander_King
    Salamander_King Senior Member
    10,975
    8,867
    New England
    I have been doing my charging outside on my driveway with stock OEM L1 charger even during winter in a few feet of snow on ground, but I worried about the charger brick being outside exposed to elements just like you. So, although I have GFCI outlet on outside wall, I have been using GFCI outlet inside of garage and connecting to the car parked next to garage. Yeah, I have a detached garage, but currently it is not in a shape to park a car inside. I think the charge unit is weather proof, but I don't know about leaving it snow. If I were you, I would put the charger brick and extension cord connector in a watertight box to protect it. Something like this would work, I think.
    #3 Salamander_King, Oct 6, 2018
    49,492
    i've been charging in the elements for six years with no precautions and no problems
  5. axle2152
    axle2152 Active Member
    266
    210
    Atlanta, GA
    2018 Prius Prime
    I can't comment on the long term but what I can say is the brick is weather proof (not waterproof), so if it rains, pours, you'll probably be fine, just don't want to leave the charger in standing water and the same goes with the plugs if you're using an extension cord.
    If you're using an extension cord (with L1 charging) I would go with heavier gauge something like 12 gauge or larger if you're going 50 ft or more. If you're going with L2 probably would need something like 8 gauge.
    I haven't had any problems with 12 gauge at L1 charging. My watt meter shows about 1,300 watt pull and does decrease if the sun beams down on the charge cord by about 20-30 watts. So I should expect slightly faster charging in the winter? (temperature coefficient...low temps, lower resistance)
