Charging Port Pins
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Gamermama66, Jul 18, 2018.
  1. Gamermama66
    Gamermama66 Junior Member
    Southern California
    Have a 2012 PIP. Few months ago had fuse issue on the freeway. Stopped dead. Took to dealer and fixed the issue but came back not being able to charge. Was told the charging port was bad and was replaced. Less than a year later, same problem. Dealer said the part holding the pins were broken and they replaced. Was told by the dealer that if happens again, they will not warranty. We're very careful plugging in so don't know why part keeps breaking. Anyone else having same issues?
    52,391
    don't recall ever hearing of it before, and can't think of any way plugging in the evse would damage the pins. did they check your evse?
    jerrymildred likes this.
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,158
    Tampa, FL
    Strange. I can't think of any reason it should break. I've read that it's not that hard to replace. Easily accessed from inside by removing the interior side panel.
