charging question
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by coolcarguy, Jul 25, 2014.
  1. coolcarguy
    coolcarguy New Member
    27
    2013 Prius Plug-in
    in my 2013 prius plug in, when i plug it into the wall socket i get a reading of 0.9 kw on the charging screen is that a normal amount of electricity ? what number do you guys see when you plug it into a regular wall outlet ?
  2. gallde
    gallde Active Member
    238
    130
    Tarrytown, NY
    The charging rate can vary with SOC and battery temp. Could be 900W as you have, or could be up to 1400W (12A @ 120 V) at low charge and a cool battery.
    51,140
    sounds right, how long does it take from empty to full?
  4. PhilBlank
    PhilBlank Junior Member
    86
    2014 Prius Plug-in
    Mine generally shows 0.9 as well. Normally I charge at 2:30 AM in the morning and it usually finishes around 4;45...but that is with the battery showing .1 or .2 miles of range remaining. . .
  5. coolcarguy
    27
    2013 Prius Plug-in
    it usually takes around three hours to charge from empty
  6. bisco
    51,140
    same with me.
  7. trentofdestiny
    trentofdestiny Master Finagler
    1,104
    227
    Harrisburg, PA
    I think I normally get 1.7kw on the screen...but I charge at 240v with the open evse. And I haven't looked at the charging screen for a while.
  8. PriusC_Commuter
    PriusC_Commuter Active Member
    914
    307
    Los Angeles/ Orange County, CA
    2014 Prius Plug-in
    With the OEM charger I would get 1.0 kW on the screen. With my GE Wattstation 240v I get 1.9 kW on the screen. I thought it would be more with 240v, but I am still happy with it.
  9. trentofdestiny
    1,104
    227
    Harrisburg, PA
    Seems like it would pull the same amps at twice the voltage, hence the shorter charging time and higher kW. Just a guess though
  10. coolcarguy
    27
    2013 Prius Plug-in
    i just checked again and its at 1.0kw on the charge screen. Im wondering how accurate is the estimated charge time ? i wish there was a screen where you can see the actual cell voltage for each cell.
  11. bisco
    51,140
    when i have a few minutes to finish charging, my screen says a half hour or better.
  12. coolcarguy
    27
    2013 Prius Plug-in
    i checked again and the estimated charge time was right on. it seems to be pretty accurate.
  13. bisco
    51,140
    at what point in the charge are you checking it?
  14. coolcarguy
    27
    2013 Prius Plug-in
    i check it all the time while its plugged in, because i just got it.
  15. coolcarguy
    27
    2013 Prius Plug-in
    the other day it said 2.9 hours till full charge and it was correct.
  16. bisco
    51,140
    what does it say at the 2 1/2 hour mark?
  17. vvillovv
    vvillovv Senior Member
    4,318
    1,499
    NY
    The highest I've seen using my OEM charger is 1.1 and typically get 1.0 so .9 doesn't sound to bad to me.
    Using a 240v charger I see 1.9
  18. coolcarguy
    27
    2013 Prius Plug-in
    2.5 hours till full
  19. bisco
    51,140
    after it's been charging for 2 1/2 hours?
  20. coolcarguy
    27
    2013 Prius Plug-in
