Charging Temperature
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by EvanB, Jul 11, 2014.
  1. EvanB
    EvanB Junior Member
    39
    Phoenix, Arizona
    2014 Prius Plug-in
    Hello,
    I have a new PIP and a question I could not find by searching.
    I live in AZ and even in the middle of the night my garage is 100+ degrees. Is it safe (no long term issues) to charge in high temp with the level 1 cord? How about charging outside with a level 2 in 100-120 degrees?
  2. Priusmpg
    Priusmpg Active Member
    628
    108
    Fremont, California
    2014 Prius Plug-in
    This is a tough one, I'm not sure but I can say the car actively cools the battery while charging.
  3. GregP507
    GregP507 Senior Member
    3,002
    481
    Although, Toyota is renown for testing their vehicles in harsh climates, therefore I'm sure their recommendations for temperature limits are set within a wide margin of safety.
  4. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
    If an alternative is available, better safe than sorry, outdoors, charge in the shade if possible. Less heat and cool cycles will definitely increase the life of the battery. Significantly? Cant be sure.
    #4 Priusmpg, Jul 11, 2014
    elementnomore likes this.
  5. GregP507
    3,002
    481
    I like that: "defy the heat!" :)
  6. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
    Take it easy man. It was a mere suggestion about charging outdoors because direct sunlight is treeing the like a big oven and in the shade, its not.
    Also just thought of something, the battery shouldn't get any hotter than what it would get when operating.
  7. EvanB
    EvanB Junior Member
    39
    Phoenix, Arizona
    2014 Prius Plug-in
    The only real alternative I see is not using it as a PIP in the summer months just as normal hybrid. The real question is it a necessary move.
    After having the heat kill the pack in my Civic hybrid and putting my insight n the edge I have been pretty strict in only parking my cars in shade / garage and ensuring the AC is on and aimed at the intake vent for the battery, But grid charging is a new element to me,
  8. GregP507
    3,002
    481
    The smilie didn't convey the irony well enough?
  9. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
    I guess its hard to convey tone with text. :whistle:
  10. GregP507
    3,002
    481
    I was making fun of the spelling mistake: "definitely" went through as "defiantly." I'd blame the auto-correct.
  11. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
    So the the smart people thing comes back to bite me. Ooops
  12. Mendel Leisk
    40,574
    Heat might have been a factor in killing Civic Hybrid batteries, but I suspect overzealous Honda engineers were the main culprit.
    Regarding AC use, here's a sentence in Honda's Aug 2010 recall notice:
    Frequent stop-and-go driving with A/C use during warm weather speeds up the IMA battery deterioration.
  13. bisco
    51,140
    i would get a scan gauge and monitor battery temps while charging for awhile.
  14. vvillovv
    vvillovv Senior Member
    4,318
    1,499
    NY
    I would do anything I could think of to cool the car / pack off some as it charges.
    There must be a reason why they are not selling in AZ so far.
    extreme heat and cold have much the same effect on the pack.
    And if you run a/c continuously while charging at those outside temps,
    from what I've noticed it would probably take 4 hours to fully charge the pack using a 240v
    and it might net ever finish using the 120v
    #14 vvillovv, Jul 14, 2014
  15. markabele
    5,084
    1,782
    Nebraska
    Not sure what you mean as far as saying cold has the same effect as heat.
  16. vvillovv
    4,318
    1,499
    NY
    "extreme heat and cold have much the same effect on the pack."
  17. markabele
    5,084
    1,782
    Nebraska
    Umm...
    But what effect? If you are referring to battery longevity, I believe you are wrong.
  18. vvillovv
    4,318
    1,499
    NY
    about what? charging temperature?
    you never know, you could be right.
  19. rxlawdude
    rxlawdude Active Member
    701
    219
    So Calif
    2015 Tesla Model S
    I don't think Honda ever approached hybrids as anything other than a compliance tool, and they certainly didn't respect the early Civic Hybrid owners when the batteries started dying (not just in hot climes). That's why when I was looking at a Plug-In, I considered the Accord PiH, but couldn't get over how shabbily Honda treated previous generations of hybrid owners.
