charging the battery pack
Discussion in 'Prius PHEV Plug-In Modifications' started by glyndwr, Oct 18, 2013.
  1. glyndwr
    glyndwr Member
    219
    42
    South Wales, UK
    I am looking for a charger to charge my plug in prius lifepo4 battery pack.
    The pack has 70 cells in series, but i may increase that to 76 cells. I have just tested the PIS system, and electronically its working ok, but i am seeing a 10v sag on the batteries under load. The batteries currently at rest read 3.1v, they are not fully charged yet. I have the spare batteries here so its not a problem for me to increase the pack size, so as a test i may install an additional 6 batteries to see what effects that have during operation. I only intend to charge fully to 3.5v and hopefuly at rest this will equate to about 3.3v charged.
    I havent got a charger yet, so i am open to suggestions on a budget.
    I need a charger and I may have access to an old mes-dea charger that was fitted to a transit converted ev.
    From the limited info I have found the charger is controlled by a pwm controller.
    I do not have access to the controller, so will the charger work without the controller as a dumb charger, or is it useless without the controller, or can any charger controller work with the charger.
    The charger is a 240v to 310 v dc charger and the profile for the charge curve is set in the pwm controller.
    So, can I use it as a dumn charger, or is it useless without the pwm controller.
    Or, if anyone has a charger they have no use for and want to sell it, let me know.
    Many thanks for the advice. Anthony
  2. mrbigh
    3,686
    699
    Long Island, NY
    It seems buy your comments that there is a combination of power charger stage and controller stage altogether !!!
    I do not think it will operate as it should with out a part missing
    dave77 likes this.
