Charging the HV battery from the mains supply.
Discussion in 'Generation 1 Prius Discussion' started by RathlinPhil, Jul 5, 2021.
  1. RathlinPhil
    RathlinPhil Junior Member
    Rathlin Island, Ireland
    2001 Prius
    I
    So..... My gen1 Prius is driving fine and the traction battery is in good health. Although I've been toying with the idea of topping up the traction battery with a high voltage charger I have acquired in order to improve MPG . Anyone been down this route? Would it be a good idea? I heard the first Gen 1s produced in Japan came with a plug in charger....
    49,372
    generally, a reconditioner is a good idea, plenty of threads here on gen2+
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    Generally.......that is wrong.
    And the longer you wait to do it, the less good it will accomplish.
    And that is a bit different than "topping up" the battery with an external charger.
    That would gain so little, if anything, that it wouldn't be worth the time and trouble.......and risk.
