charging time.
Discussion in 'Gen 3 Prius Main Forum' started by Rick1956, Apr 21, 2019.
Tags:
  1. Rick1956
    Rick1956 Junior Member
    Little Rock, AR
    I've been noticing my 12 plug in seems to take less time to charge. Today it took an 1 hour 45 minutes to charge from almost empty. What gives?
  2. hill
    8,168
    It's possible you're experiencing capacity loss, as that is one of The Tell-Tale symptoms. If you lose one or more kWh's of capacity - that can be represented by roughly 20 minutes of charge time - presuming you are charging at 3.6kW's from the wall.
    49,434
    is this all of a sudden?
    i have lost 15-20%, but slowly, over 7 years,
    best to measure with a kil-o-watt meter or other.
    but another good test is to drive in on back roads in ev, starting with a full charge until the engine starts, see how many miles you get.
