Charging Times
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by fortytwok, Sep 8, 2013.
  1. fortytwok
    fortytwok Active Member
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    I didn't see this previously posted / accumulated so here goes.
    Consumer reports stated 3.5 hrs to fully charge the PiP so I'm interested to see real world numbers given I've been at 1/3 that at Chargepoint and just over 1/2 that at home using 120v.
    If anyone is well these off I'd be interested in hearing your location
    240v - 72 minutes
    120v - 2:04
    52,395
    metro boston: 120v, 3 hours. 240v, 1 1/2 hours. +/-. i assume you're talking about fully depleted ev portion.
  3. iplug
    iplug Senior Member
    2,456
    1,704
    Rocklin, CA
    PG&E and Roseville Electric, just northeast of Sacramento: 120v, 2.5 hours give or take a few minutes
  4. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    SCE in So Cal, approximately 2:20 on 120v, and that is pretty consistent over the time I have had the car.
  5. SLOW_RR
    SLOW_RR Member
    155
    84
    Finger Lakes Region of NYS
    Finger Lakes Region of New York State... 2.5 hours like clockwork on the dedicated 15amp 120v outlet. I think some of the difference in times is due to the actual voltage at the outlet which can vary due to many factors.
  6. fortytwok
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    yes, definitely zero - full
    I'm curious - where are you using the 240v ? I've used 5 in metro boston - Wellesley Whole Foods, Nissan Framingham, 99 in Milford + Marlboro and chargepoint in Hopkinton.
    Usually pretty anal about timing and have gotten consistent 70-75 min charge times so wondering if a difference between 2012 and 2013s could exist
  7. El Dobro
    El Dobro A Member
    7,093
    3,271
    In New Jersey, it takes around 2hr 40min with EVSE1 and 1hr 20 min with EVSE2.
  8. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :)I charge Level 2 at home and work. I allow 1.5 hours and never been disappointed.
  9. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    Same setup here- and 1.5 hrs is a good figure for me too.
  10. bisco
    52,395
    at home and work, i've never used a public charger, i'll have to offer to go to whole foods for my wife!:p
  11. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    It doesn't have much to do w/the location in terms of city and state.
    However, if one has an EVSE installed at home, it'll likely be running at 240 volts. If you use an EVSE at a commercial location, it likely be at 208 volts, and be a bit slower, unless the on-board charger of the PiP ups its amperage to be the same as charging at 240.
    Toyota Rav4 EV Forum • View topic - Fresno to Gilroy (CA) trip report is a chart for the Rav4 EV. Rav4 EV has a 10 kW on-board charger. My Nissan Leaf Forum • View topic - 3.3 vs 6.6 KW on-board charger - charging times? is a chart for the Leaf. The '11 and '12 Leafs have only a 3.3 kW OBC and can't go over 16 amps at 208 or 240 volts, IIRC. The '13+ Leaf has an optional 6 kW OBC.
    I'm not sure what the max draw/output of the PiP's OBC is but IIRC, it's definitely no more than 3.3 kW and could be as low as 2.x kW.
  12. bisco
    52,395
    i just charged from .2 ev miles, 1 hour and 25 minutes. L2 at home.
  13. fortytwok
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    Let me know if you ever do time your charge at Whole Foods. I'm usually entering that lot on "fumes" and have done a full charge in 72 minutes on quite a few occasions.
    Looking through the responses so far I'm wondering if Toyota made some small changes for the 2013 as I'm getting 15-18min faster at 240v and 25-30 at home but unless someone else can charge at my house we can't compare that one ;)
  14. bisco
    52,395
    that would be good if true. i would announce it if i were them. 70 minutes at whole foods... i hope they have a lot of free snacks!:p
  15. El Dobro
    El Dobro A Member
    7,093
    3,271
    The only place I've ever been to where they charge for a slice of pizza by weight. o_O
  16. bisco
    52,395
    i beter lose a few lb's before i go in then.:cool:
  17. fortytwok
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    Unfortunately in Wellesley there's just one GE charger but at least they posted more restrictive signs.
    Twice before that the adjacent spots were taken up by - yup SUVs... I just parked parallel and charged anyway
  18. iplug
    iplug Senior Member
    2,456
    1,704
    Rocklin, CA
    Just checked the Toyota website, looks like they still claim the same charging times they posted on the 2012 models:
    Charging Time - 120V/240V:~3 hrs/~1.5 hrs
  19. SJ PiP
    SJ PiP Member
    190
    35
    120v, 2h15min
  20. fortytwok
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    so far the worst charging time reported is an hour faster than what ConsumerReports stated
