Charging tips?
Discussion in 'Prime Plug-in Charging' started by kwollner23, Mar 14, 2020.
  1. kwollner23
    kwollner23 New Member
    Houston
    2020 Prius Prime
    Hi does anyone have any tips for how to keep the electric motor in good condition? Like what to do or not do when charging, etc. Thanks
  2. Tideland Prius
    16,624
    The electric motor is probably the most reliable item on the Prius. We've owned 4 generations of Prius (Gen 2, 3, 4 and Prime) for years and the electric motor has never caused any issues.
    Are you thinking the high voltage battery? For charging, here are some tips (That are also found in the owner's manual)
    • Try to use the "Charge By" timer function. This means you tell the car what time to finish charging. (Different from telling the car when to start charging). This reduces the length of time that the battery sits "full" between finishing the charge and when you start driving. It's better if you start driving as soon as it's finished charging
    • When leaving on vacation or not driving the vehicle for a long time, park the car with close to an "empty" battery. By that, Toyota means let the car go into hybrid mode (HV mode) before parking the car.
    • Avoid charging the car immediately after driving in high heat or after the car has been parked in the heat for a while. Heat reduces the life of the battery. The car may not charge or will charge very slowly to help preserve the life of the battery until the battery temperature is lower
    • When you turn off the car in the summer, the car will ask if you would like to use the battery to power the A/C while charging to help keep the battery cool. Select Yes. (it always defaults to No so you have to tell it).
    • Park in the shade where possible or use tinted windows and/or sunshades to keep the interior cool
    • Avoid hard acceleration in high heat (at least until the interior is cool).
    • Use the Pre-Cool function when charging (or when plugged in) to allow the interior to cool while the car is plugged in, reducing the load on the battery to cool the car after you unplug and drive off. It also helps with range.
    phlack, MSantos, jerrymildred and 2 others like this.
  3. loue2
    loue2 Junior Member
  4. loue2
    loue2 Junior Member
    Press button for 5 seconds
    Until
    Charge mode icon
  5. bisco
    52,431
    that's for charging while driving. won't keep the motor in good shape
    jerrymildred and Rob43 like this.
