Chasing a "poor MPG" problem, possible excessive drag on front wheels?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Ryanpergallon, Jan 27, 2025.
  1. Ryanpergallon
    Ryanpergallon New Member
    I just got this 2008 Prius and it was reporting 39.8mpg, I wanted to try to get to his to 45 and as a preventative measure I cleaned the MAF and replaced the 12v battery then the MPG dropped significantly and in the city I'm getting about 25 mpg.
    Now I'm chasing this issue and trying to determine where the loss is coming from. I have a feeling the system is relearning it's energy management system after replacing the battery and has yet to recover since I had to disconnect it the other day to repair the combo meter.
    So far I've replaced spark plugs, MAF, new valve cover gasket, new PCV valve, removed and cleaned fuel injectors, checked on tire pressure and performed a dr Prius battery evaluation... No dice.
    Today I decided to inspect the brakes and determined they could use a replacement, during this job I noticed significant drag when turning the front wheels by hand, it took a lot for force. I removed all brake pads and there was no change.
    What is considered an acceptable amount of drag on these wheels? If this is not normal, what could be causing this? Wheel bearings on both sides appear adequate when doing the side-to-side test, car drives straight as an arrow and makes no sound when driving at any speed.
  2. Ryanpergallon
    Here is the video, looks like it didn't embed in the post
  3. Ryanpergallon
    Sorry first post. If Imgur isn't allowed, can someone suggest a way to attach a video?
  4. PriusCamper
    PriusCamper Senior Member
    11,977
    4,869
    Pacific Northwest, USA
    39mpg and 45mpg are very close to each other... Boosting your tire pressure up a few PSI at a time until you notice less traction and then reducing a few PSI will help you find the max MPG. My preference is 47psi in front and 45psi in back in Summer and lower than that in winter.
    But too often people buy the wrong tires for Prius and get sold "safer" high traction tires instead of Low Rolling Resistant (LRR) tires, which could easily be your only problem.
    But in general this cold time of year on short trips around town your MPG is normal... The true MPG test is a long freeway drive in 75' to 85' Summer weather with Summer Gas blend and no wind and no stopping. I usually get 52mpg at that point with my Prius on trips to California, but 39mpg in coldest parts of winter driving around town is fairly common.
    Anyways, welcome to PriusChat. I live a little more than an hour north of you if you ever need help with diagnosis, spare parts, a battery pack or just want to be friends. :)
  5. Paul Gregory
    Paul Gregory Senior Member
    1,363
    356
    Alberta
    2024 Prius Prime
    XSE
    If your problem really was excessive drag, the energy would manifest itself somewhere as heat. You would probably smell or hear something abnormal if that were the case. I think it's more likely that you're not burning fuel efficiently.
    PriusCamper likes this.
  6. PriusCamper
    11,977
    4,869
    Your pics, videos and links are limited until you have enough participation. This is to protect PriusChat from Spammers.
    Just spend some time reading and commenting on here and by the end of the day or soon after that restriction on your account will go away.
  7. Ryanpergallon
    Thanks for the input everyone! My current combined mpg has gone down to about 34mpg from the 39 before I changed the 12v battery my highway only is about 38 currently. I was hoping to get it back up to 45ish combined but I'd be happy to get back to the 40.
    My front wheels won't turn freely when I spin them by hand, they turn but then stop immediately when I let go. My biggest mpg killer appears to be stop and go. The ICE kicks on almost immediately after I take off from a stop and the battery isn't being use as aggressively as I would expect. I feel like the wheels not spinning super freely is adding some resistance which needs to be managed by the engine, which is why I'm going down this path.
    I'm going to try to post a direct link to YouTube.
  8. Paul Gregory
    1,363
    356
    Alberta
    2024 Prius Prime
    XSE
    I've been here over a year, and I still can't post much.
    #8 Paul Gregory, Jan 27, 2025
  9. Danno5060
    Danno5060 Active Member
    350
    179
    Wyoming
    My Gen 2's gas mileage went up after I took off the rear brake drums and dumped out all the dust that had been circulating around in there.
    Are you in neutral when you turn the front wheels by hand, or is the other wheel moving in the opposite direction?
    Maybe it's time to change the transaxle fluid - but I wouldn't expect that to buy you that much.
  10. Ryanpergallon
    Rear drums need to get done I have the parts, did front brakes last night.
    The other wheel would turn opposite direction but I was met with a lot of resistance still. When I tried in neutral It felt easier on the individual wheels, but there wasn't much of a difference wheel to wheel.
    I was thinking Transaxle fluid too. Its in the mail, I'm going to hopefully get that done in the next week or so. But I wouldn't think old fluid would present so much resistance, we shall see!
  11. Danno5060
    350
    179
    Wyoming
    I didn't see your video the first time I read this thread (empty box). Now that I can see it, it does look like you're having to fight it to turn the wheel a bit more than normal. I don't know if you'd want to undo the axle nuts, but it's common for some mechanics to tighten them with an impact wrench rather than a proper torque wrench. If those were overtightened, I don't know if you can just back them off and torque them to the proper torque as I don't know what that would have done to your wheel bearings.
    Depending on where you live, and how you drive, Prii can be pretty easy in the brakes. My Gen 2 had well over 200K miles and while I did the front bearings a couple times, there was still plenty of pad left - on both the front as well as the rear. If you're in a high corrosion area, I suppose you could get some rust buildup underneath the pads which makes your wheels harder to turn.
    I ended up doing the rear on my Gen 2 only because I developed a slight leak on one of the slave cylinders. I don't know how that happened, but it was squealing just a little bit and I was trying to sell the car, so I ended up doing a complete brake job on the rear. That's when I noticed there was a bit of brake dust and road dust circulating around in the rear brake drums. After doing the rear brakes I noticed about 5 more MPG.
    For the transaxle fluid, I wouldn't use anything but the Toyota WS stuff. I got a funnel and attached it to some clear tubing I got at the hardware store so I could feed that into the fill hole from the top. Unless you've got some other arrangement that works, that's the only way I know to get the fluid into the transaxle rather than all over the floor.
  12. Paul Gregory
    1,363
    356
    Alberta
    2024 Prius Prime
    XSE
    There's no way to free-wheel the front axle, because it's connected directly to the gas engine and the electric motor through a planetary differential at all times. There is no clutch and there is no actual neutral. If you could turn the drive wheels, it would have to rotate the electric motor. Difficult to do without considerable drag.
