Chasis Stiffening Plate and Muffler?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Freedom, Jun 24, 2008.
  1. Freedom
    Freedom Active Member
    535
    69
    Northeastern MA
    Chassis Stiffening Plate and Muffler?
    I just ordered my Pri yesterday. So I can't just go out to the driveway and LOOK to get an answer on this.
    From the photos, it seems this plate needs to be removed each time you have a muffler change?
    On my other cars, I've always gone to Midas for mufflers; and they last me perhaps 2 years and I need a new one.
    I saw a few threads about the stiffening plate, who likes it, what it does etc. But I didn't find anything re it's interaction with muffler changes.
    Just wondering if anyone has an experience with this?
  2. Five5Six
    Five5Six New Member
    56
    Los Osos, CA
    Why would you require a muffler change every two years?, and any muffler guy should be able to do his work without any problem with the plate installed.
  3. jdenenberg
    jdenenberg EE Professor
    3,852
    1,847
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Since the Prius muffler is made of high quality stainless steel, very few have needed to be replaced. Some catalytic converters have failed in early Prii, but that's a separate issue.
    Besides, the stiffening plate is just bolted on and can be removed in 5 minutes.
    JeffD
  4. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    This is a complete non-issue. I'm not sure I've even heard of anyone needing their muffler replaced on the Prius to tell you the truth and certainly not every 2 years.
    Anyway, there's a stiffening plate there anyway from Toyota, the replacement stiffening plate is just more rigid. Either would need to be removed and either will come off quite easily.
  5. patsparks
    10,664
    567
    Adelaide South Australia
    You had an American car you needed to frequently change the muffler on.
    This is a Toyota. My last Toyota was a 1990 Camry, had 290,000km on it and the original mufflers when I sold it last year. Most likely still has the same mufflers today.
    Love the stainless steel.
  6. Freedom
    535
    69
    Northeastern MA
    Nope, Honda. Only ever owned a Honda; until now. :D
    I didn't realize this is a replacement; I thought it was a new add on piece. That helps, to know that.
    So does that plate have to be done BEFORE putting on the skid plate?
  7. efusco
    19,891
    1,192
    Nixa, MO
    Nope, either order is fine, they don't overlap.
  8. ZC1
    ZC1 Junior Prius Owner
    711
    Metro Detroit
    Re: Chassis Stiffening Plate and Muffler?
    The direct answer to your question is:
    Either part (plate or muffler) can be easily removed/replaced independently of each other.
    The stiffening plate is not near the muffler and the muffler coupling is 2ft behind the muffler and easily reached.
    In fact, both can be removed while you are laying on the ground, no need to raise the car.
    Just so you know.
    ZC1
  9. patsparks
    10,664
    567
    Check, I think Honda must make some cars in the USA? :D
    I just thought I would try and guess.
    If you are a bit chubby with short arms like me you might need to jack the car and block it up, just a little to reach the plate or muffler.
  10. BIGGDOGG
    BIGGDOGG New Member
    298
    Morristown,NJ
    I have never needed to replace the muffler on any car I owned. (I only owned 1 before my pri but it was near 100K miles and 8 yrs old)
  11. mrblaise
    mrblaise Go Lakers!!
    2,248
    525
    Southern California
    I think the last time I replaced a muffler was when I owned a 1968 Camaro ...
  12. dipper
    dipper Senior Member
    1,242
    252
    hmm.... Rhode Island.
    You sure your neighbor(s) did not just put road salt into your cars' mufflers? ;)
  13. Freedom
    535
    69
    Northeastern MA
    If they did anything, it was OCEAN salt! He hee.
  14. cairo94507
    cairo94507 Active Member
    923
    36
    Auburn, CA, USA
    Not to slam Midas, but if they sell a muffler which needs replacement every two years why are they still in business? ( as a disclaimer I do not believe the OP about this fact)
  15. Freedom
    535
    69
    Northeastern MA
    Sorry. It seems like every 2 years, I am not sure HOW long it is. I know I've had at least 3 ( 1 being the original) mufflers on the 1998 Honda I am planning to trade in for the Pri I have on order. I also know I get the absolute cheapest model they offer (they have different "grades") The muffler is guaranteed, all I pay is the labor each time they have to replace it. I probably would have spent less overall if I'd just gone for a better muffler in the first place. My trips are all very short, and I am near the coast. I've been told those are the factors which play into my needing one so often. (short trips, near coast, cheapest thing out there)
    That wasn't really the point of my question, I was just curious about the way the part fit together because I can't go out in my driveway and look; yet!
  16. Genoz World
    Genoz World ZEN-style living
    797
    La Canada
    here's the bottom line, you wont have to worry.
    PATSPARKS- my friend, you look strong enough to lift the prius all by your lonesome self - yes, this is a compliment.
    cheers.
  17. dwreed3rd
    dwreed3rd New Member
    742
    Marietta, Ga
    I wouldn't go back to MIDAS if their mufflers only last 2 years. I haven't replaced a muffler in 30 years. Had cars for 51 years. Lowest mileage traded with 75K. Two over 100K, one of which is a 2000 Toyota Avalon XLS w/107K. I'd find another muffler shop. I can't imagine what car or driving conditions would go through a muffler every 2 years.
