chassis code 2019 awd-e prius?
Discussion in 'Gen 4 Prius Technical Discussion' started by davran, Apr 3, 2019.
  1. davran
    davran Member
    99
    97
    BC, Canada
    2019 Prius
    Base AWD-e
    All,
    I'm new to Priii. What would the chassis code be for my '19 awd-e? Where would I find it?
    In front of the passenger seat there's a plastic cover that says pull, what info do I find there? I gave it a tug and it didn't come off; is there a special way of doing this? I don't want to wreck it.
    Thanks, Dave.
  2. alanclarkeau
    alanclarkeau Senior Member
    7,044
    7,584
    near Brisbane, Australia
    It should be on the dealer's invoice. And in the front of your Service and Warranty book?
  3. davran
    davran Member
    99
    97
    BC, Canada
    2019 Prius
    Base AWD-e
    I'm looking for something like: zvw55.
  4. alanclarkeau
    7,044
    7,584
    Yes, that's on my invoice from the dealer, as well as in the Service Booklet. It might have been stuck in the front of the Owner's Manual?
    It has to be somewhere in the paperwork you got with the car.
  5. davran
    davran Member
    99
    97
    BC, Canada
    2019 Prius
    Base AWD-e
    could it be XW50 ?
    #5 davran, Apr 3, 2019
  6. Elektroingenieur
    2,515
    3,260
    Three Touring
    The model code is ZVW55L-AHXGBA or ZVW55L-AHXHBA, depending on the trim level. It should be shown on the certification label, on the B pillar inside the driver’s door.
    The VIN or frame number, stamped into the body as a deterrent to auto theft.
    Yes; the Repair Manual (more info) explains how to remove the front floor caution plate cover:
    “L9RF1C” is a number used by Toyota Canada. It’s not very useful after you’ve bought the car, since the service information, parts catalog, etc., all refer to the model code, which—along with the VIN or frame number—is how Toyota Motor Corporation in Japan identifies the car. As far as I know, “chassis code” isn’t a Toyota term.
    FuelMiser and alanclarkeau like this.
  7. davran
    davran Member
    99
    97
    BC, Canada
    2019 Prius
    Base AWD-e
    Thank you for the help.
    Elektroingenieur likes this.
  8. davran
    davran Member
    99
    97
    BC, Canada
    2019 Prius
    Base AWD-e
    On the door jamb, ZVW55L-AHXEBA.
    krmcg likes this.
