Chassis stiffing plate
Discussion in 'Gen 2 Prius Main Forum' started by STRESS, Nov 2, 2005.
  1. STRESS
    STRESS New Member
    I see that such an item is offered here as an accessory, has anyone installed one and found that it makes a noticeable difference? Sorry if this has been covered in an earlier post but I am new. Thanks
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    From a search with key words Stiffening Plate
    http://priuschat.com/index.php?act=Search&...tiffening+plate
    Short answer is yes it works.
  3. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    short answer...
    ya i like it. less body roll on curves. i have a fairly steep downhill stretch between my sister's house and mine. it has very sharp turns in it to mediate the grade a bit. definitely a noticable difference. more solid feeling. i have never had much of an issue with handling on the freeway before the plate so cant say if that will improve.
  4. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    It makes a huge difference. I can feel the road now instead of the car bouncing around. It corners now. When you get one, you'll be happy with the purchase. It's simply put: awesome.
    It improves both low and high speeds.
  5. windstrings
    windstrings Certified Prius Breeder
    6,280
    378
    Central Texas
    Ditto!
  6. V8Cobrakid
    3,790
    152
    i actually find myself going slower so i can enjoy the car more, the road more, and my mpg more :) to and from work ( roughly 5 miles) i haven't been getting below 50mph. I usually average over 60 going to work. hehe.. fun :)
