cheap front bonnet lift struts
Discussion in 'Gen 3 Prius Accessories and Modifications' started by abubin, Nov 24, 2020.
  1. abubin
    abubin Member
    193
    92
    Malaysia
    I saw this and thought...wth..so cheap. Might as well give it a try.
    Working find so far. A bit stiff and no so "soft" when opening. For the price, I am not complaining.
    Burna J likes this.
  2. Leadfoot J. McCoalroller
    8,143
    7,644
    Pennsylvania
    2018 Prius c
    If they aren't stiff in warm weather, they'll be useless in the dead of winter.
    Yours probably won't ever see weather that cold, but they make them the same way for the whole planet.
  3. SnowMexicanuck
    56
    66
    Quebec, Canada
    I bought mine on Aliexpress and only installed one as it's fine on its own. Kept the other one as a replacement for later.
  4. abubin
    abubin Member
    193
    92
    Malaysia
    Yes, the bonnet is made of aluminum so it is quite light. One is definitely enough. Good idea!
  5. ASRDogman
    ASRDogman Senior Member
    7,804
    3,980
    Where did you get those?
  6. Ed Beaty
    Ed Beaty Active Member
    334
    311
    Salt Lake City
    Y'know, I like that Original Equipment rod: simple, simple; requires no installation; works perfectly in ANY weather, and not only is it cheap, it's FREE!
  7. ASRDogman
    7,804
    3,980
    The original is fine. But not free. Part of the cost of the car. :)
    If it's inexpensive enough, it's worth looking into for ME.
  8. Ed Beaty
    334
    311
    Salt Lake City
    "The original is fine. But not free. Part of the cost of the car."
    Actually, that's WHY it's free: because it comes WITH the car....no extra costs involved.
  9. ASRDogman
    7,804
    3,980
    nooooo, not free.....It is INCLUDED in the pricing.
  10. Ed Beaty
    334
    311
    Salt Lake City
    "nooooo, not free.....It is INCLUDED in the pricing."
    YES, free, because it has already been paid for..
  11. abubin
    abubin Member
    193
    92
    Malaysia
    ASRDogman likes this.
  12. ASRDogman
    7,804
    3,980
  13. NewHybridOwner
    NewHybridOwner Active Member
    607
    283
    W. Michigan
    But what about that extra weight? What's going to happen to your mpg (or Km/l? -- or is it l/100Km?)?
  14. ChapmanF
    18,531
    "Sunk cost". Ignorable for the purpose of future economic choices. Cost of keeping the prop rod that came with the car: $0. Cost of replacing it with anything else: > $0.
    Now, if you had the option of buying the car without a prop rod because you wanted to spend the money on your own....
    Of course, Marketing would probably make that option part of an extra-cost package with lighted door sills and whatnot.
    Ed Beaty likes this.
  15. abubin
    abubin Member
    193
    92
    Malaysia
    The extra weight can be offset by you shedding 1 pound from your body. Drink less 1 can of beer.:rolleyes:
  16. Jim Swart
    Jim Swart Member
    57
    Portland, OR
    Using the attachment points shown in the video resulted in the hood not opening very wide. Using different attachment points the hood now opens about as wide as the normal (1st) hood prop opening. With the kit I received the factory hood prop would have to be removed if you were to mount the strut kit on the passenger side. You now have to forcefully close the hood because of the struts resistance.
      File size:
      146 KB
  17. redprius2011
    redprius2011 Junior Member
    46
    Georgia
    does anyone know if original hatch lift struts work as front bonnet lift strut?
  18. abubin
    abubin Member
    193
    92
    Malaysia
    Just tried it and does not work. Cause the hatch lift is too long for the front. I lift the bonnet all the way up and it's still too long.
    redprius2011 likes this.
  19. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    The hatch struts would also be way too strong for the light aluminum hood. The hatch is a much heavier steel assembly, and thus requires struts that have greater pressure/force.
