Cheap Roof Rack Options
Discussion in 'Gen 2 Prius Main Forum' started by rogerthat, Sep 29, 2021.
  1. rogerthat
    rogerthat Active Member
    410
    127
    Georgia
    I posted this in the accessories forum, but since this forum gets more traffic and because I need a rack asap, I'm posting here too. Hopefully, someone has a recommendation.
    Has anyone had any success with a universal fit roof rack? I've seen a few on Ebay and Amazon that claim to fit a 2nd gen Prius, but I prefer to hear it direct from a forum member that model X works great.
    I need a rack for temporary use to transport a 24ft extension ladder - I'll probably only use it 2x a year so the most I'm willing to spend is $100. I definitely don't plan to keep it installed.
    #1 rogerthat, Sep 29, 2021
  2. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Rent a truck from Lowe's, Home Depot, or (insert company name here). Some come with bed racks and can be rented for $19 for the first 90 minutes, then $5 for each additional 15 minutes.
    Hard to beat for occasional use.
    SFO likes this.
  3. rogerthat
    410
    127
    Georgia
    Thanks, but prefer the roof rack option. Waiting to see if someone has tried one of those budget universal racks.
  4. xliderider
    8,140
    3,277
    Honolulu, HI
    I read through the Amazon reviews of the universal racks and some actually came off the car while carrying loads.
    Others looked promising, but still cost above $100 and used straps which passed through the passenger compartment to secure the rack crossbars.
    That was when I realized I already have an old Yakima roof rack, and devised a way to make it "universal". I've mounted it on our 2011 Gen 3 Prius, 2010 Toyota Camry, and 2014 Toyota Corolla very solidly.
    https://priuschat.com/index.php?posts/3084850
    Perhaps you can find someone selling a similar rack system for cheap and buying the necessary components to make your "universal" rack for occasional use.
    The Yakima SST towers and crossbars are engineered really stoutly, and they will be far stronger than the cheap ones found on the universal racks.
    SFO likes this.
  5. rogerthat
    410
    127
    Georgia
    Yeah, seems to be hit or miss with some of those universal racks.. really depends on the model car if it works well or not. I'm also looking at some used options, but really want to keep this in budget based on my intended use. I'll also likely never exceed 50lbs on the rack.
  6. xliderider
    8,140
    3,277
    Honolulu, HI
    Keep in mind that static weight isn't all that is involved. Cornering and acceleration/deceleration (braking), can multiply the forces the rack, mounts, and lashing are subjected to.
  7. Another
    Another Senior Member
    1,819
    520
    Naples, Florida
    Why not try one of these? Free shipping and free returns. $46
    item B083T53K3P
  8. xliderider
    8,140
    3,277
    Honolulu, HI
    Those racks/crossbars require the car to have rails already installed on the roof. The OP has a Gen 2 Prius which doesn't have rails.
  9. Another
    1,819
    520
    Naples, Florida
    Good luck
  10. rogerthat
    410
    127
    Georgia
    I took a chance and bought a Saris Roof Rack. The downside is that it doesn't come with the correct clips, but I got it cheap enough to experiment with bending/modify the existing clips to fit. Does anyone on this forum still have a Saris roof rack? If so, can you please provide the clip measurements.
  11. koco
    koco Member
    113
    38
    Las Vegas
    You can score a roof rack from a 2002 to 2007 Ford Escape for $25 or so. You would need to drill holes in your roof though and the width might not be suitable. It is a high quality rack though if you're willing to do the drilling.
  12. Another
    1,819
    520
    Naples, Florida
    What does a real Gen 2 roof rack cost?
  13. alftoy
    alftoy Senior Member
    1,132
    518
    Saskatchewan, Canada
    The Saris clip situation is quite similar to that of Yakima (they are shaped the same, and hold onto the same place)
    Prius Clip Racks
  14. rogerthat
    410
    127
    Georgia
    Hmm, so you think Yakima clips would work with a Saris rack? If so, any idea what clip # for yakima?
  15. alftoy
    1,132
    518
    Scroll farther up the page.
  16. rogerthat
    410
    127
    Georgia
    I see that. Just to be sure, are you saying Q clip set #5 for the front and Q Clip set #124 would fit the Saris Rack without any adjustment? If that's your webpage, do you still own the Saris rack? If so, any chance you can get me the exact dimensions of the Saris #20 clip? thanks
  17. alftoy
    1,132
    518
    Not my page, more here, not sure if its suitable for your case.
    Prius Permanent Rack Pads
    $20 Ebay
    yakima landing pad 7 | eBay
  18. rogerthat
    410
    127
    Georgia
    Yeah, definitely not considering any type of permanent mount. I've already bought the Saris rack... now I just need to find some compatible clips. So hoping someone who owns a Saris rack can provide the exact measurements of the #20 clips, and I'll go from there.
    #18 rogerthat, Oct 22, 2021
  19. alftoy
    1,132
    518
  20. Another
    1,819
    520
    Naples, Florida
    rogerthat likes this.
