Cheap solution if you're down to 1 ignition key 2001-03 Prius
Discussion in 'Generation 1 Prius Discussion' started by 3prongpaul, Feb 21, 2017.
  1. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    956
    728
    Boulder Hybids, Boulder, CO
    Don't ever lose your last "chip" key, it is a major PITA and expense to make the car drive again.
    If you only have 1 master key for your Gen1, make a few $2 "plain silver" copies at hardware store, remote the master chip head under the dash.
    If you only have 1 valet key, order 1 master metal key cut by code at the dealer, duplicate at hardware store, then remote mount valet chip head. See my video;
    m.wynn likes this.
  2. Brian in Tucson
    Brian in Tucson Active Member
    981
    453
    Tucson AZ
    2003 Prius
    I don't have a Valet key, tho. Nice video, Paul. I think I would hesitate to defeat the security system on the car, tho.
    I just got a duplicate cut and programmed. Ace, here in Tucson, can do it about $75. Walmart might be able to. And have a 'dumb key' made to get in the car if the keys get locked in. I keep one in my wallet.
    You're right, losing your only key is a nightmare!
    #2 Brian in Tucson, Feb 22, 2017
  3. 3prongpaul
    956
    728
    What ACE made you is called a clone key (they didn't program anything, they cloned your existing key). Usually people with only a valet key have them cloned since they cannot add any more keys the official Toyota way.
    If you have a true Master key (black head) an alternate option (if you have a bit of time) is to order master blanks on Ebay for $7-10 each or so, have the key "cut" at your hardware store for $2 then properly program the key yourself using the official Toyota procedure (aka "chicken dance"). Keys properly programmed the Toyota way is a more correct way to make additional keys, and cheaper than cloning.....but you need a true master key to do it.
    #3 3prongpaul, Feb 22, 2017
  4. Ed R
    Ed R New Member
    Marietta, Ohio
    2003 Prius
    You can by transponder keys and key fobs cheap at TRANSPONDER. Like under $15. They send the instructions to do the right "PEDAL DANCE" to program them your self
  5. 3prongpaul
    956
    728
    Correct, as long as you have a MASTER key you can self program the appropriate new keys.
    If you only have a VALET key cloning or bypassing the immobilizer are your only options.
