Cheapest Catalytic Theft Device suggestions?
Discussion in 'Gen 2 Prius Main Forum' started by mchenrycruiser, Sep 23, 2020.
  1. mchenrycruiser
    mchenrycruiser Junior Member
    Cali
    I was going to make one myself but can't find anyone to install it. Couple said liability issues. And I don't know how to get underneath the car to do it myself with a lift.
    Any suggestions for the cheapest, easiest to install installation kit?
  2. Moses Bruh
    Moses Bruh Member
    97
    29
    imo , would be a ~170$ cat security shield plate shipped and install it urself. You will likely need to jack the car up on all 4 with jackstands as high as safely possible, to be able install it on your back under the car but if could probably be done just doing the front or from the side. You will need a metal drill bit to make holes for the security screws and rivets, if you dont have the security head or a rivet gun, then just get metal screws (reccomend different types of heads to make removal harder by thieves). If you dont want to do the dirty work, a mechanic will be able to do it in 30 mins or less but will probably charge 50-100$.
  3. PriusCamper
    PriusCamper Senior Member
    11,056
    4,499
    Pacific Northwest, USA
    Motion sensitive car alarm... OR even better you could rig alarm up to a doll head under there with eyes that light up and have it scream really loud if the car gets jacked up... :) Or for $22 you could buy a 4x8 sheet of plastic coroplast (what election signs are made of) and cover the underside of the car, which may be easy for the thief to cut through if they were determined, but might be enough of a visual deterrent to discourage them.
    Data Daedalus likes this.
  4. Jimbolimbo
    Jimbolimbo Junior Member
    Global Citizen with a focus on the western USA
    I'm starting to think the best deterrent is just to pull out the stock cat, scrap it for $1,200, put in a generic one for $200.
    The car's not registered in a carb state so I couldn't care less about that.
    Conversely, maybe a bunch of safety razor blades welded all around the access area, so thieves just get shredded trying to get in there, that could be nice.
  5. PriusCamper
    11,056
    4,499
    Problem with booby traps, is it's very hard to explain your intention to unintended victims.
    I think'n my strategy is going to be buying an aftermarket cat and then whenever I'm in California visiting family I'll place an ad online to get someone to pay for the swap and pay me a bit for them saving money on a less expensive repair.
