Check eng lite on after cleaning throttle plate
Discussion in 'Gen 2 Prius Technical Discussion' started by A J, Feb 16, 2011.
  1. A J
    A J Junior Member
    29
    Lillian Al
    Just went for a test drive after using 3m's 3 part kit to clean tp and intake. Check eng lite came on after <1 mile. Went and filled up, light still on. Car runs fine. I cut a shirt into long strips to snake into intake, past tp to soak up all the fluid. Mentioning this because this is the only deviation from the instructions. Yes, the fuel cap is on tight, any suggestions?
  2. richard schumacher
    7,664
    1,043
    United States
    You have discovered why it is better to remove the TP from the housing before cleaning it. Nothing to do now but drive. The CEL will go out five starts after the cleaner and gunk have burned out of the engine, I think...
  3. A J
    A J Junior Member
    29
    Lillian Al
    Yeah, I figured that the little tube inserted past the sensor far enuf to not get any cleanser on it. Guess I figured wrong, If the light stays on longer than mentioned, is there any fix for it?
  4. Patrick Wong
    18,200
    6,493
    1. Buy a can of mass air flow sensor cleaner. Remove the MAF sensor from the air cleaner housing, clean the sensor, then reinstall.
    2. The Toyota TSB regarding Classic throttle body cleaning suggests that you remove the air cleaner housing from the throttle body. Then apply throttle body cleaner to a cloth or paper towel, and use that to scrub off the deposits on the throttle body interior and throttle plate.
  5. A J
    A J Junior Member
    29
    Lillian Al
    Thanks, I appreciate the prompt, informative replies, gonna go get the MAF cleaner, and then try and tackle my ICE coolant change, AFTER reviewing info on this site!!
  6. A J
    A J Junior Member
    29
    Lillian Al
    The CEL went off on the way home from the auto parts store!
  7. David Beale
    David Beale Senior Member
    5,963
    1,987
    Edmonton Alberta
    Of course. You scared it by purchasing the cleaner!
