Check engine after EGR cleanup....yet no error code...
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by kye04, Feb 18, 2016.
  1. kye04
    kye04 Junior Member
    38
    Europe
    Hi. My car was just fine. But one day, i decided to go to a mechanic to clean the EGR pipe. Only the pipe, not the whole EGR. It was an extremely simple operation a mechanical one, not electrical etc...
    Starting from that day, when i go with the car, from time to time, check engine lights up. For a fraction of a second to up to 2 seconds....then it dissapear.
    The car behave itself without a problem. But still the on-off check engine is really annoying.
    So a went to the dealer. Put the car on tester.
    Result: no code error !!!!
    I went to another garage , put another tester on the car..... no error....
    How is this possible ? How can i actually see what the error is if nothing is stocked in the ecu of the car???
    Any of you ever encountered that ?
    My car is a Prius Plus 2012.
  2. Former Member 68813
    3,524
    981
    US
    it's a long shot, but have you checked oil level?
    if not that i would reset the ECU by 12V battery disconnect.
  3. kye04
    kye04 Junior Member
    38
    Europe
    Oil is fine....
    I`ll try the reset....
  4. kye04
    kye04 Junior Member
    38
    Europe
    Nothing worked....
  5. Mendel Leisk
    38,721
    There's an electrical connector at the intake manifold end of that EGR pipe, that has to come off before you can get one of the pipe flange bolts. Maybe something partially haywire with it now? Just a guess.
