check engine, (!) and VSC light
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by aanimate, Oct 7, 2009.
  1. aanimate
    aanimate New Member
    25
    Was driving yesterday and suddenly triangle, check engine, (!) and VSC lights came on. I stopped and restarted my 2005 prius, but red triangle and check engine light still on. Car drives the same, no problem at all.
    My tank was half full, I pulled to gas station and filled the tank, and the lights went away.
    So I thought that I didn't put the gas cap tight enough.
    Today I was driving home and the same thing happened, all 4 light came back. I filled my tank again and lights went away.
    Does anybody know what the problem is. Could it be a bad gas cap?
    :confused:
  2. Blegate
    Blegate Prius Gen III 2013
    132
    Vancouver, WA
    Codes... you need to get the codes generated by the car's computer. A toyota place can do this or if you know someone who has a scanguage.
    Sorry
  3. Patrick Wong
    18,210
    6,513
    I suppose you know that when you tighten the gas cap, you need to tighten to get at least one click? Also, when the cap is removed, you can look at the black rubber O-ring to see if it looks damaged.
    However, even if the cap is bad, that would not cause the master warning triangle, (!), and VSC lights to come on. The latter two lights indicate a brake problem which might be related to the 12V system. Maybe your inverter coolant pump has failed so your inverter becomes slightly overheated. This causes the DC to DC converter voltage to sag and the skid control ECU turns on those warning lights. Then, when you stop for gas, this gives the inverter a chance to cool down and restores normal operation of the DC to DC converter temporarily.
    I suggest that you visit your Toyota dealer very soon to have the DTC retrieved to confirm or deny the above.
  4. aanimate
    aanimate New Member
    25
    Thanks so much for the help.
    I am bringing the car to the toyota dealer tomorrow.
    The thing is though, even I if don't drive the car for extended time( 4-8 hours) the two lights will come on, and to make them go away I just have to put the gas in.
    The other interesting thing that dealer told me after I describe the problem is; sometimes the lights related to a loose fuel tank cap can come back (even though they went away for a while), so I need to drive it couple more times to make it go away.
  5. richard schumacher
    7,666
    1,047
    United States
    I think Patrick is right about this. Your weather is not very hot, so the inverter gets just warm enough to panic, and then it cools down enough while you're buying gas to clear itself. See a dealer. If your 60 month/60K miles warranty is still in effect the inverter pump replacement will be free.
  6. aanimate
    aanimate New Member
    25
    As I mentioned in the post before the light still come on even if I don't drive my car for more then 8 hours, that should be plenty for it to cool down.
    Anyways I just connected the OBD II tool and it says "no codes found".
    Very strange.
  7. johnjamis
    johnjamis Junior Member
    79
    KY
    It is easy to tell if the inverter pump is working. With the car in "ready", just look in the inverter coolant reservoir(next to the inverter). If there is turbulence, the pump is working. If the pink fluid surface is dead calm, it is off.
  8. William Lowe
    William Lowe New Member
    Raleigh
    Same symptoms no codes invertor is working.
    Brodgah likes this.
  9. Brodgah
    Brodgah New Member
    Kansas City
    Having the exact same problem. Battery normal charge, just had 12v replaced about a year ago as well.. checked coolant and levels are fine... sort of spinning
  10. JC91006
    16,827
    8,600
    Easiest way to figure this out is getting the codes read on the car. No guess work after that
    Raytheeagle likes this.
  11. Brodgah
    Brodgah New Member
    Kansas City
    Took the car in for codes and showed no codes..... ):
  12. JC91006
    16,827
    8,600
    If you had warning lights on while the codes were being read, there would be codes. You would need to get a Prius compatible code reader to do this.
    Is your hybrid fan on? This is the fan on the rear passenger side of the car. If that fan is not on, my guess would be that your inverter pump has failed. You can check the inverter coolant reservoir and see if there's any movement/waves in the coolant. If there's no movement, then the failure is the inverter water pump (somewhat common after 100k miles since last replacement)
  13. Brodgah
    Brodgah New Member
    Kansas City
    If the fan is on, it's not noticeable or is loud sounding- checked coolant ... seems to be semi swirling but it may just be from the wind here in Kansas City
  14. bisco
    52,386
    how many miles on her?
  15. Brodgah
    Brodgah New Member
    Kansas City
    250,000
  16. bisco
    52,386
    do you do your own work? if so, you should get mini vci, to properly read the codes.
  17. dejanna
    dejanna Junior Member
    usabcd
    I also had the check engine, red triangle, yellows (!) and VSC light come on. I suspected something to be overheating because the rear seat fan comes on when I drive it. I have drove it twice since lights came on, drove slow seemed a little noisier and idled a little more when stopping but other than that it drove ok up to 45mph. Will check codes tomorrow with OBD.
  18. Prodigyplace
    12,676
    11,830
    Central Virginia
    Also check the back seat fan and filter for dust and blockage.
  19. vlalra
    vlalra Junior Member
    KY
    I have all the lights in the title along with the big red triangle. The code I got was p2601. I have replaced the water pump and refilled the Reservoir. I reset the computer and drove great for 10 miles at 45 mph. Than all the lights came on again.
    The back seat fan come on as soon as I start the car and is loud. Until the lights came on I never heard it.
    Please help it is my only form of transportation and I don’t have the money to take it to shop.
    What trouble shooting could I try?
    I have a 2005 Prius.
  20. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    Nobody can help you until you scan the codes with a scanner that can read Toyota codes and post them here
    And no a generic code reader cannot read all the codes.
