Check engine code p261b
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Pruisdriver2015, Sep 30, 2019.
  1. Pruisdriver2015
    Pruisdriver2015 Junior Member
    Ventura
    Hello , we have a 2015 pruis . Last week the check engine light came on , had the code read and checked fluids . It threw the p261b code and added coolant fluid as it was low. The light went off on the way home . Figured it was the low fluid causing the light. Drove over 200 miles and the light came on again . Fluids are fine , same code .the light went off again after this . Does this sound like the water pump or something else ?
  2. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    Water pump
    Raytheeagle and bisco like this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    Welcome to Prius Chat (y).
    That’s a code for the water pump, so it might be time to replace it;).
    How many miles on your Prius?
    Can you hear the pump run and is it noisy?
    Do the hoses on the discharge feel like they are warm once the car is on?
    Good luck and keep us posted (y).
