Check engine just lit-up
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by kensiko, Mar 28, 2015.
  1. kensiko
    kensiko Member
    260
    58
    Qc, Canada
    2014 Tesla Model S
    My Prius just reached 200000 km this week. I bought it at 180000 km 2 years ago, I don't drive it that much simply because I work from home.
    Today, a sunny day, 0 degrees, the check engine just lit-up. I opened the hood and checked fluid levels, all OK. I started it and listened to the engine, running as usual. However, when the motor stopped (hybrid ON), I can hear a high frequency noise. I don't remember hearing this noise, but I don't think I ever opened the hood with the engine Off but powered On.
    How can I get the check engine code ? I assume I need a connector, right ?
  2. kensiko
    kensiko Member
    260
    58
    Qc, Canada
    2014 Tesla Model S
    Sorry for the wrong section.
    51,141
    did you check the gas cap tightness?
  4. kensiko
    kensiko Member
    260
    58
    Qc, Canada
    2014 Tesla Model S
    Just checked it, was tight
  5. bisco
    51,141
    hmmm... might want to check the 12 volt. auto parts stores will sometimes read codes for you.
  6. kensiko
    kensiko Member
    260
    58
    Qc, Canada
    2014 Tesla Model S
    OK I'll check the voltage
  7. kensiko
    kensiko Member
    260
    58
    Qc, Canada
    2014 Tesla Model S
    My father got a tool to get the code, we'll check that tomorrow. Where do you plug it ?
  8. bisco
    51,141
    obd port. on board diagnostics, i think under the dash.
  9. Mendel Leisk
    40,574
    OBD is pretty much directly below the steering wheel column. It's not that obvious, look with a light.
  10. Mike500
    Mike500 Senior Member
    2,593
    766
    Not all OBD II tools are compatible with the Prius.
    ScanGauge II is known to work.
    A mini-VCI cable with Techstream software is what basically Toyota uses.
  11. xliderider
    xliderider Senior Member
    8,055
    3,222
    Honolulu, HI
    FYI, it's normal to have a high pitched whine when the Prius is in Ready mode, it's the inverter.
  12. kensiko
    kensiko Member
    260
    58
    Qc, Canada
    2014 Tesla Model S
    K thanks. My mpg is pretty low, there's a good chance it's the 12v battery, we'll see this afternoon
  13. kensiko
    kensiko Member
    260
    58
    Qc, Canada
    2014 Tesla Model S
    P2a00
    Seems to be a oxygen sensor issue.
    12v battery is 11.8v no accessory. 11.7 with accessories, drops to 11.3 when turning ON
  14. bisco
    51,141
    guess what?
  15. kensiko
    kensiko Member
    260
    58
    Qc, Canada
    2014 Tesla Model S
    Ok some news. We cleared the code, then hopped on the car and started it. It didn't start, lights were on in the dash.
    Checked again the 12V battery, was 9 Volts! After a few tries, I was able to start the car.
    Need a new battery, and fast.
  16. kensiko
    kensiko Member
    260
    58
    Qc, Canada
    2014 Tesla Model S
    Battery replaced with the optima one. Took 15 minutes. Code disappeared. It's running well now, mpg went up.
    Robert Holt likes this.
  17. bisco
    51,141
  18. bisco
    51,141
    hate to be a pain, but you should check the voltage.:cool:
  19. kensiko
    kensiko Member
    260
    58
    Qc, Canada
    2014 Tesla Model S
  20. bisco
    51,141
    dead cold?
