Check engine light after recent service
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by cooldyood, May 31, 2016.
  1. cooldyood
    cooldyood Junior Member
    45
    Wash DC
    Last week, I took my 2006 Prius with 180k miles to Meineke for oil change. They pointed out that my front brakes need work and brake fluid needs to be replaced. I've been told about brakes by another mechanic, so I went ahead and took both suggestions from Meineke.
    Two days later, my check engine light is on. I'm not very trusting of mechanics, thought I'll get advice from you guys. Do you think there's foul play involved?
  2. M in KC
    M in KC Active Member
    358
    106
    KC, MO
    You need to have the codes pulled to be able to determine why the check engine light is on. While I love a conspiracy theory as much as the next guy retrieve your codes and go from there.
  3. DonDNH
    DonDNH Senior Member
    1,711
    654
    Nashua, NH
    Four Touring
    Most frequent cause for the CEL is a gas cap that isn't properly sealed.
  4. ericbecky
    ericbecky Hybrid Battery Hero
    4,381
    3,242
    Madison, Wisconsin
    Error lights after an oil change can sometimes be from oil overfill.
    Get the codes read and report back here.
  5. cooldyood
    45
    Wash DC
    Should I just take it back to Meineke and ask them to retrieve codes? Will they do it?
  6. cooldyood
    45
    Wash DC
    Sorry, one more thing - since the service MPG has dropped from ~45 to ~35.
  7. bisco
    51,155
    they should do it if they have the proper toyota code reader, which they should have if they actually changed the brake fluid. to be honest, i'm impressed that the brakes work at all.:cool:
  8. cooldyood
    45
    Wash DC
    Just dropped by Meineke, attached are the codes and description of the error.
  9. dolj
    dolj Senior Member
    8,217
    4,187
    Wellington, New Zealand
    I can only find a couple of those as valid for a 2006 Prius. The combination of the ones I could find would indicate the checking the 12 V aux battery would be in order.
    One indicates that the brake bleed was not done properly.
    I'd suggest getting the car re-scanned with a Prius aware/capable scan tool.
    #9 dolj, May 31, 2016
  10. cooldyood
    45
    Wash DC
    I will take it to them right now but I have a feeling they will point me to the error description displayed by the scanner. Any thoughts about that?
    Also, am I ok to drive the car? I don't want to do any major damage while the light is on...
  11. Kenny94945
    Kenny94945 Active Member
    843
    418
    Sausalito
    2016 Prius v wagon
    I did not look up the codes.
    You could try...disconnecting the 12v battery to see if the codes clear and then reattached a reader and see what codes remain. I would NOT have Meineke do this based on your story.
    Yet, a check engine light usually does not have a delay so I don't think they deliberately "set you up".
    Servicing errors...baring the brake bleed procedure errors....air leak at the airbox could be suspect and explain the mpg loss.
    Good luck.
